Temporary front license plate ideas
Old Nov 17, 2012 | 12:38 PM
sc_s13's Avatar
Originally Posted by golgo13
3M double sided tape
/thread
Well I don't want to use 3M tape because I don't want it there all the time. I only want to slap it on in highly enforced areas or when I park near downtown or on the street. I already considered that, but it left glue stains on my buddy's Evo so I turned away from that idea.
Old Nov 17, 2012 | 12:54 PM
evo unknown's Avatar
I have seen others zip tie the plate to one of the two horizontal slits (above the FMIC and below the front mitsu emblem). You could line the edges of the plate with something padded to prevent it from scratching the paint. Some marterial that is sticky on one side and a soft pad on the other. There is something i am trying to describe between the underside of the rear wing pills and the trunk. Then u can simply cut the ziptie and remove anytime u want.
I am really surprised it left glue stains. I used 3mm tape to attach a trunk lip. When i removed it a year later it all easily came off with a "goo gone" product.
Old Nov 17, 2012 | 01:09 PM
AreSTG's Avatar
if I needed a front plate, I would just ziptie it to the mesh in front of the ACD area I think. If it fits.
I even still have the hole in my bumper from the stock front plate holder (i first reg'd the car in TX). Anyway, I'd rock zipties somehow, and remove the plate for the track. simple, effective, done.
I am going to assume that looks matter to most people,more than to me, that are concerned with this topic though
Old Nov 18, 2012 | 02:41 PM
sc_s13's Avatar
Actually done the zip tie method a couple times! Worked pretty well for inspection before but they are cracking down now. Plus I don't want to make my friends or my girlfriend wait a couple minutes every time I park to fiddle with zip ties.
Old Jan 9, 2013 | 10:34 PM
silverevo05's Avatar
bump for any other ideas o does anyone have a stock IX bracket lying around that they don't need
Old Jan 10, 2013 | 04:57 AM
whiteEvo08Y's Avatar
Also the same problem i am having, need to mount my front plate up but don't know how to do it.
Going to have to start custom making me a bracket
Old Jan 10, 2013 | 06:02 AM
eastcoastoutlaw's Avatar
I've used 3M double sided tape for years with no problems
Old Jan 10, 2013 | 06:03 AM
NODAKevo's Avatar
My state requires a front plate but I do not drive my Evo around often enough to really worry about it. I did get a ticket just before Christmas for not having one on my Integra though. I was going to fill in the license plate holes in the front bumper to make it a little cleaner.
So my idea for the Integra is to bend the top of the license plate 90* and drill 2 holes on the underside of the air dam and then fold up the bottom section of the license plate so that if would effectively make the license plate normal width but probably only a few inches tall. Does anyone know if that would be legal? I have done no research into it so it may be considering you wouldn't be able to see which state the plate is from the front, only the numbers/letters.
Old Jan 10, 2013 | 08:34 AM
llDemonll's Avatar
^ call the DMV. usually modifying your license plate is illegal, just depends what mood the cop is in
Old Jan 10, 2013 | 09:51 AM
vortico's Avatar
I got one of those universal mounts from Oriley's (plastic piece) attached it through the mesh on the lower right corner of the bumper (infront of the ACD pump) and screwed the plate to the mount. It's held up for at least two and a half years so far. It is removable but I might not go as far as temporary. Perhaps playing with the mounting options you fab up something that could be removed quickly and easily.
Old Jan 10, 2013 | 11:59 AM
projektevo9's Avatar
Just curious does anyone know if Pa has a law about you having a front plate?
Old Jan 10, 2013 | 12:37 PM
veilside prius's Avatar
I mounted mine in the same place with only 2 zip ties on the top and it held for years with no issues. I put double sided tape on the lower back of it to keep from scratching the paint.
Old Jan 10, 2013 | 01:28 PM
hiboost2.0's Avatar
Nope you're good bud, you don't need a front plate. I'm in jersey (need a front plate) and I have a bunch of people who work with me from PA, none of them have front plates.
To the OP, I used 3m double sided tape because I didn't want to drill holes in the bumper in case I were to ever sell the car to someone who doesn't need a front plate... Maybe try some really strong velcro? Not sure if that would hold up and I don't want to be liable if your front plate comes flying off LOL
Old Jan 12, 2013 | 05:20 PM
Thank you sir
Old Jan 14, 2013 | 12:11 PM
sc_s13's Avatar
I ended up using two L brackets from Ace hardware and attached 4 rare earth metal magnets to them. I double sided taped 4 stacks of rare earth magnets to my 9 bumper above the intercooler. Either the left or right side went works. I'll post pics later, but so far it's good up to 70-75 mph. No tickets! I left my local beat cop a Merry Xmas note on it and he took it lol
