How to access intake manifold lower bolts?
Old Nov 20, 2012 | 04:55 PM
Grimgrak's Avatar
What are the best tools to use to get in there? I can't make ratchet or wrenches fit
Old Nov 20, 2012 | 05:16 PM
heel2toe's Avatar
I dont remember my exact combination but I do recall using a 3/8 ratchet along with a long extension, a swivel, a short extension and the proper socket(14mm?)
Be creative and dont get frustrated. Sometimes its best to take a rest for 5 minutes, settle down and an idea will pop into your head. That works for me at least
Old Nov 20, 2012 | 05:49 PM
whiteEvo08Y's Avatar
++2 I agree 100% And MORE . All i can say is take lots of breaks in between,
i almost drop kicked my fender while do my intake swap
Old Nov 20, 2012 | 06:11 PM
icmanevo's Avatar
There is no easy way to do it. I have logger hands so i had my wife get the socket on there... a 4 or 6 inch extension with a swivel ratchet and I think I used a wobbly 12mm. After the wifes small hands got the socket on I broke them loose.
Old Nov 20, 2012 | 08:14 PM
Grimgrak's Avatar
Hmm any idea on the torque specs to put them back?
Old Nov 21, 2012 | 09:12 AM
boostedwrx's Avatar
Swivel socket
Old Nov 21, 2012 | 10:51 AM
cmspaz's Avatar
Tight enough. You're never getting in there with a torque wrench so as long as you use a new gasket and are getting enough torque on the bolts to crush the raised part of the gasket you'll be fine.
Old Nov 21, 2012 | 04:27 PM
Grimgrak's Avatar
Does using more extensions make the torque readings, read higher or lower?
Old Nov 21, 2012 | 04:42 PM
boostedwrx's Avatar
Operator error can screw it up. If you hold the torque wrench centered over the axis of fastener it should be the same. My opinion anyway I don't have the math to figure it out That's good enough at Boeing though hehe. Try to use no extensions though or the shortest one possible. My 2c.
Old Nov 21, 2012 | 05:50 PM
sobo's Avatar
Could always pull the motor
Old Dec 9, 2012 | 10:52 PM
evopaul's Avatar
I tried the same too, but couldn't remove these bolts
Old Dec 10, 2012 | 12:31 AM
Grimgrak's Avatar
IT worked for me just need lots of patience to make sure the sockets are on tight.
kpt6
Apr 17, 2013 01:12 AM
zasboy
25
Oct 14, 2012 12:44 PM
