Poor fuel mileage
Old Dec 17, 2012 | 09:22 AM
  #31
fastyouth1313's Avatar
Originally Posted by FlatBlack
Your poor fuel economy is most likely a combination of many factors.
The first factor is most likely due to colder temperature this time of year. Now that its getting colder out the car will definitely loose efficiency and use more fuel due to the difference in winter fuel. The engine also uses more of its fuel maintaining operating temps when its cold out. Have you change fuel brands recently, maybe one with more ethanol?
Secondly, maintenance plays a huge role in fuel efficiency. Lots of little issues can contribute to the overall performance of the engine. How is the air filter? if its dirty the engine will have to work harder to overcome the restriction loosing efficiency and fuel economy. Maybe the injectors have become dirty and the spray pattern is not as optimal as it should be causing the engine to not run as efficiently as it once did. Are you still running the test pipe? You haven't installed a CAT by chance have you?
Another huge factor is driving habits/routines have you change how you drive recently? New/different daily commute? maybe closer of farther away? On average are you driving faster then you did before? I know my evo gets much better fuel economy when I drive slow, such as cruising at 60 or less vers 75+.
Unfortunately, there probably isn't just one good answer to your problem, if there is and you do find out what it is please do share with the us.
new air filter, im running cleaner through the injectors on this tank, i use cheveron 91. same daily drive to work and home, i drive for the best fuel eco i can get, and yes im still runiing the test pipe. new o2 should be here today though
Old Dec 17, 2012 | 06:17 PM
  #32
Well I got the o2 In And filled up with 91 from cheveron. Last tank 144 until the gas light came on.
If I get this figured out ill let you know! I'm still open to ideas.
What I've done so far
Tune from a reputable tuner
New tires
New spectre 9inch filter
New UEGO sensor to make sure it's reading right
New OEM front o2
Old Dec 17, 2012 | 06:44 PM
  #33
DisgustipatedM3's Avatar
Damn, something is definitely wrong. I get 200-250 miles/tank... on E85. Hell, I'll get 200 miles on a tank flooring it all the time. Even with 255mm Nitto NT05's. I get 300-350 miles/tank on 91...
Make sure your battery is still good and your alternator isn't being raped. Just a thought. Also, did you check spark plugs?
Old Dec 17, 2012 | 07:04 PM
  #34
i have a pc 680 and its still working well. the plugs are good i checked them. i assume the alternator is doing good doesnt show signs of needing to be replaced
thank you though!
Old Dec 17, 2012 | 07:08 PM
  #35
10isace's Avatar
I'm going to take a stab at this and I really hope I help you out.
I have a small exhaust leak at the down pipe and O2 housing connection. This makes the idle in closed loop read 14.7 on the WB. My STFT is good at idle, almost 0.
Logging at WOT shows it getting leaner than usual. I thought nothing of it since this happens every winter, but I had to richen it up quite a bit. Therefore I am losing mpg.
My theory is since I have a small exhaust leak my WB will read 14.7 at idle and the trim looks good. At WOT, the WB will read leaner than reality and trying to tune it out by adding fuel will cause a loss in MPG.
Check for exhaust leaks. If there are none, then I'm inclined to go with the front O2 sensor replacement.
Old Dec 17, 2012 | 07:12 PM
  #36
thank you very much! i plan on getting it smoke tested after the holidays, i pout a new front o2 in today and filled her up to the brim! so im hoping that will fis it ill know in about 3 days. smoke test is defiantly going to happen
Old Dec 17, 2012 | 07:23 PM
  #37
Huy's Evo's Avatar
whats your set up on e85? i m getting 170 a tank on e85 mix driving, or if u can send me your map so i can look at how aggressive your tune
Old Dec 18, 2012 | 07:56 AM
  #38
Well I'm in a 2900 lb Evo 8 RS so that helps a LOT in all situations but sure, I can try to download the map. My tune is pretty balanced, not aggressively tuned for power.
Also I'm on Evo 8 10.5 hotside so spool is pretty rapid, which doesn't help MPG. But if I drive like a regular person I get 240-250 out of 14 gallons (not that I usually run it that low.) When I drive it hard I get 200~ miles on a tank. That's with like 5-8 full WOT runs from 1st through 3rd gear or random bursts into the 4k RPM torque band.
Old Dec 18, 2012 | 12:46 PM
  #39
Old Dec 18, 2012 | 08:54 PM
  #40
Huy's Evo's Avatar
sure let me see the timing map.. i dont know where to adj to get the best mpg.. i got it tune for power right now..
Old Dec 25, 2012 | 04:05 PM
  #41
Hijackers!!! Lol it's cool
But, still no fix....
To add to my list of new parts I put in though
Treadstone 340lph fuel pump with new fuel sock so I'm going to fill up then report back.
Still looking for suggestions, or anybody who went through this problem and found a fix! Thanx!
Old Dec 28, 2012 | 10:51 PM
  #42
Well I just put new fic 1100 high z in so I will see if that fixes it
Old Dec 30, 2012 | 05:57 PM
  #43
hiboost2.0's Avatar
Let me know how it goes man, I'm interested on what could be the cause of this!
Old Dec 30, 2012 | 06:21 PM
  #44
I'm going through gas now, it looking like it could of been fuel pump though... The fuel sock looked nasty
Old Jan 4, 2013 | 11:04 PM
  #45
slimjim1804's Avatar
Originally Posted by snowmastergt
Check your front o2 sensor. That was the cause for my horrible mpg with my talon. If you can log your car check your fuel trims and see if they are way out of wack.
If the fuel trims were far off, wouldnt you see a rich condition idle/cruising?
Posted from Evolutionm.net App for Android
