Poor fuel mileage
Old Jan 4, 2013 | 11:06 PM
  #46
fastyouth1313's Avatar
My idle is open loop no o2 sensor feedback. My cruise is spot on though.
These injectors/tuner (tscomp) are what fixed my bad mileage.
Old Jan 5, 2013 | 12:28 AM
  #47
10isace's Avatar
Nice! You weren't in idle open loop to begin with were you?
I have the same injectors and love them.
Old Jan 5, 2013 | 03:53 AM
  #48
Evo9_Dubai's Avatar
Did you figure it out? I'm having the same issue with 16mpg no matter how I drive.
Although I'm running a PTE 6266 @ 28psi so I'm not sure if that is the reason for my poor MPG.
Old Jan 5, 2013 | 08:10 AM
  #49
Grimgrak's Avatar
I'm blaming my **** mpg on ID's on the fact that the stock ecu for evo 9 doesn't seem to have a fuel cut when you lift off the throttle it hangs 5-10 seconds then cuts.
Old Jan 5, 2013 | 08:15 AM
  #50
My previous tune was in open loop with other injectors was in open loop yes. Tom got it squared away
Old Jan 5, 2013 | 08:19 AM
  #51
With a big turbo like that you tend to stay out of boost during driving. It could be a number of things causing your poor MPG. I pretty much changed everything that deals with MPG till it was fixed.
New
UEGO sensor
Front o2
Tires
Fuel pump
Injectors
Air filter
And I'm good now
Old Jan 5, 2013 | 08:20 AM
  #52
Tuner should be able to fix that for you.
Old Jan 5, 2013 | 10:29 AM
  #53
Evo9_Dubai's Avatar
New
UEGO sensor
Front o2
Tires
Fuel pump
Injectors
Air filter
And I'm good now
I have a feeling that it could be my front o2.
Will get it replaced and report back.
Thank you !
djelliott978
Jul 20, 2016 02:47 PM
guyver858
Sep 16, 2013 06:39 AM
Carter19
11
Apr 30, 2010 08:32 PM
kmcconn9
24
Oct 5, 2009 03:43 PM
freakitgood
Mar 19, 2009 12:13 AM
