Poor fuel mileage
Old Dec 12, 2012 | 07:36 PM
fastyouth1313's Avatar
Poor fuel mileage
Making my own thread about this....
Mods in signature
Only getting 150 miles a tank, staying out of boost. No boost leaks, keeping the boost gauge in the negatives. AFRs at cruise and idle right at 14.7 my walbro is whining but they all do that. Weather is very cold here. Anybody encounter a problem like this and figure it out? Find a fuel leak anywhere??
I'm at a loss any input would be great!
Old Dec 12, 2012 | 07:38 PM
snowmastergt's Avatar
Check your front o2 sensor. That was the cause for my horrible mpg with my talon. If you can log your car check your fuel trims and see if they are way out of wack.
Old Dec 12, 2012 | 07:42 PM
joseph143's Avatar
i get 110 regardless of driving habits... but i know why mine is so bad...
best of luck bro.
Old Dec 12, 2012 | 07:44 PM
I can log, if the front o2 sensor was bad wouldn't it throw a code? And my wide band shows correct. Ill do some research , but thank you very much for your input
best of luck bro.
Why is yours bad?
Old Dec 12, 2012 | 09:18 PM
If my wideband is reading correctly at idle cruise and WOT could the front o2 still be the reason for bad gas mileage?
Thinking might be on its way out. But my wideband is reading correctly
Old Dec 12, 2012 | 10:18 PM
joseph143's Avatar
Where is your wideband located? Some people think if its to far from the engine it cant read accurately... I'm nuetral here because i have no clue. However if you have or know someone with a tactrix cable you can log short term fuel trim or o2 feedback. Same thing diff name. And if it reads close to 0 +/-2 some say as high as 4-6, then you o2 is fine and compensating properly. If it read nil or doesnt fluctuate then its toast.
Check your fuel pressure... It should be around 43.5... Especially since youre running a 255. If you dont have an aftermarket fpr you could be overrunning it.
Also check your driving habits. Its not only keeping the car out of boost that gets good gas mileage. If you keep rpms to low 15-2000 and try to accelerate you put the engine under much more load then if you were at 2500. On the highway its better to down shift to accel then to try to in 5th or 6th. Things like that seem small but they add up.
Next time you try to fill up make sure the fuel light is on... Top off the tank. And see how many gallons you put in. It should be between 11 and 12. If its not your gauge could be off.
Park your car and put pig mat or a couple shop towels under the fuel lines down the drives floor pan and on the transmission in the engine bay. Idle the car for 10 minutes or so and check for wetness on the towels. They will absorb fuel and tell you if you have a fuel leak
If you can log a cruise you can fuel the afr over a time and check to see if it goes crazy at any points.
Idk its late i'm fresh out of ideas
Old Dec 13, 2012 | 04:57 AM
ReaperX's Avatar
Fuel trims may be out of whack. Take a 20 min drive and log ltft then sit for 5 minutes and idle for stft. Add them together and see how much they are compensating.
Old Dec 13, 2012 | 06:32 AM
my wideband is located right after the bend in the downpipe, its a AEM UEGO and i followed the install instructions to a T! I shift around 2500-3000. Im at such a loss although i threw a P0134 but my wideband is reading correctly though. if the sensor was bad wouldnt the afrs read off?
Old Dec 13, 2012 | 06:35 AM
i will do that. your saying to add them together? what should id equal? at idle the afrs are at 14.3-15
and at cruse they are at 14.7-15.2
^^ those are with me throwing the code of P0134 Im so confused and angry!!!
Old Dec 13, 2012 | 11:52 AM
FlatBlack's Avatar
I thought my economy was bad at 230 ish per tank.
Has the economy always been that bad with your current injectors?
Old Dec 13, 2012 | 11:54 AM
nope, just recently since the weather change.....
230 i would be so happy!!
Old Dec 13, 2012 | 12:24 PM
bump, any ideas, or expirences with an issue like this would be great
Old Dec 13, 2012 | 06:11 PM
Old Dec 13, 2012 | 07:04 PM
MRolla's Avatar
Check for vacuum leak egr valve hose. Boost leak and yes this cold weather will drop your mpg.
