how long should a tune last?
Old Dec 20, 2012 | 02:26 PM
SmurfZilla's Avatar
changing weather from fall to winter (esp. if you live up north).
Values don't change in the cells. Environment and mechanical issues (O2) are the only things that can make a tune seem "off")
Old Dec 31, 2012 | 07:09 PM
RussellDaniel's Avatar
Forever, weather may play a variable. Remeber tuning is done during certain conditions when conditions change it may change your tune a little. shouldnt be to a degree of worry though.
Old Dec 31, 2012 | 11:42 PM
slimjim1804's Avatar
Originally Posted by CBRD
as always if we can take a look let us know!!
sometimes with dramatically changing weather- we have to make idle changes to compensate for super high or low IAT's etc-- and if there is a dramatic swing there may be some changes- its hard for us to duplicate every condition here on the day we tune the car-
just let us know!
cb
Now that's customer service!
I was also under the impression that tunes lasted for the longevity of the car. (Barring mechanical failure, or drastic change in weather conditions.)
Posted from Evolutionm.net App for Android
Old Dec 31, 2012 | 11:56 PM
fastyouth1313's Avatar
I would guess your front o2 if that's the code your pulling. If you are set to idle off of o2 feedback (closed loop) and your o2 goes bad it will affect your idle. If they have you set up in open loop at idle I would do a battery reset and let the iac try to learn the idle again.
Is your rpm changing/ bumping around when your AFRs do that?
And once you figure out the fix...PLEASE POST WHAT WAS WRONG!!! That way the community can learn. Incase someone has an issue like this
TouringBubble
Oct 10, 2025 11:11 AM
benselements41
Oct 13, 2014 03:44 AM
SRT4toEVO
Aug 6, 2013 02:09 PM
akqowns
20
Oct 17, 2012 04:37 PM
Nkryptd1
41
May 19, 2011 09:49 AM
