front end vibration
Old Dec 26, 2012 | 12:06 PM
latreille's Avatar
front end vibration
I have a vibration in the front end that comes and goes? I tried a second set of wheel and all the ball joints and tie rods are tight. Its an evo 8 at stock ride height with stock suspension. I am thinking a bad cv joint but would like oppinions on it before I just start changing parts. Like I said the the steering wheel will shake for a bit at hwy speeds and then go away, then come back, any thoughts.
Thanks
Old Dec 26, 2012 | 08:24 PM
elim0's Avatar
check drive shafts for any damage/splits in the rubber seal/ leakage. my friend had a dc5 and his car would vibrate at speeds above 80km/h.. was his drive shafts
Old Dec 28, 2012 | 04:58 AM
latreille's Avatar
bump anyone else
Old Dec 28, 2012 | 03:51 PM
cmspaz's Avatar
Originally Posted by latreille
bump anyone else
Just check stuff dude, there's only so many things, be it a joint, an axle, or a bushing. Something has play.
Old Dec 28, 2012 | 04:40 PM
ReaperX's Avatar
CV Joint you will here clicking when driving a slow circle or figure 8 in a parking lot. Have a friend walk beside the car while you do this.
Wheel bearings could be another possibility. With the car on the ground, grap the wheel perpendicular to the ground and give it a shake, then parralel. You will here and feel any play in it.
The least expensive cause could be your lca bushings. I had a shake in the steering wheel at highway speeds and real bad when braking above 65mph. It felt like the wheels were moving back and forth under braking.
Another possibility could be a busted lower front motor mount. This also caused some of my vibration.
Hope that helps. Good luck troubleshooting.
Jonno99
Sep 12, 2016 03:35 PM
slicksta69
15
Jun 20, 2016 09:23 AM
edub173
Lancer Troubleshooting
Jan 14, 2014 12:14 PM
DisgustipatedM3
Oct 22, 2012 05:40 PM
EvoVIII03
18
Sep 19, 2010 02:45 PM
