wanting to make 450whp
Old Jan 4, 2013 | 02:11 PM
Dead-Man Inc's Avatar
Noobie question
I'm thinking Down the Road of purchasing ATP GT3037S turbo
http://www.maperformance.com/atp-tur...n-evo-8-9.html
I'm looking to make 450whp, do you suggest the Turbo i posted above or are there other turbo kits you guys can suggest?
i've chosen ATP to for its Stealth look
Mod List on my Evo in Signature
Advice's appreciated
and i take it an IC upgrade would be a must
Old Jan 5, 2013 | 07:59 AM
KevinBoosted's Avatar
Stealth look? Most upgraded and not huge turbos can look stealth. If I were you I'd just get an FP green. Fast spool and can handle 450 easily. Put it on race gas and watch what it does
Old Jan 5, 2013 | 08:35 AM
cmspaz's Avatar
Stock turbo E85.
Anything else is just lag if that's all you're looking to make.
Old Jan 5, 2013 | 08:41 AM
4RETECH's Avatar
Originally Posted by cmspaz
Stock turbo E85.
Do they have E85 in Bahrain??? LOL
Either way, any of your FPred/BBK-B/EF3 should do.
Old Jan 5, 2013 | 09:14 AM
Don't Think so
Running on 93oct all day ..
i'm currently searching the forums between the Diffrence between fp green & fp red, whichever's best to reach the 450whp on pump gas
Old Jan 5, 2013 | 09:26 AM
grillpt's Avatar
What's your budget?
A Green will not get u there, btw.
Old Jan 5, 2013 | 09:31 AM
evo8426's Avatar
Originally Posted by grillpt
What's your budget?
A green will make 450whp on 93.
Old Jan 5, 2013 | 09:32 AM
What's your budget?
2500$ .. the extra cash would go for supporting mods i.e core IC + Extra's to reach that kind of HP safely
Old Jan 5, 2013 | 09:38 AM
mario's evo 9's Avatar
A used fp red? There selling for around 1,500 ..
Old Jan 5, 2013 | 09:45 AM
grillpt's Avatar
Ok you're right, it can, but you'll have to throw every supporting mod possible at it. There are way better choices to make that amount of power on pump gas.
Old Jan 5, 2013 | 09:51 AM
grillpt's Avatar
$2500 is gonna go quick. Start checking the F/S threads, you'll need an intercooler and injectors, whether or not you want to buy a used turbo is up to you.
Old Jan 5, 2013 | 10:01 AM
10isace's Avatar
Do you have upgraded injector?
Have you looked into MAP's EF3 or EF4?
Old Jan 5, 2013 | 10:10 AM
No i havn't upgraded the Injectors.. i'm checking out the MAP EF3 & EF4 right now
Currently im budgeting how much i'll need for supporting mods i.e IC & Injectors ..etc & 2500$ for the turbo alone
Old Jan 5, 2013 | 10:25 AM
10isace's Avatar
I agree with grillpt. You may have to go the used route. Is there much of an Evo following out there? I'd imagine shipping is going to eat up a chunk of change.
I bought used injectors and turbo and had decent luck. I bought a new FMIC. So it can be done. Don't forget to get new OEM gaskets, bolts, studs, nuts and washers. Try to get the turbo with the J-Pipe or you may have to get a IX J-Pipe. I personally would get new lines too. $h!t adds up!
Old Jan 5, 2013 | 12:07 PM
jspecteggy's Avatar
You thinking about throwing in cams too? That's a decent chunk of HP/TQ for it's cost.
