idle issues
Old Jan 20, 2013 | 08:37 AM
latreille's Avatar
idle issues
My car at a light will just go from 900rpm to 1200rpm for a few seconds and go back to normal. it will also idle up for a second when you turn on an accessory or turn the wheel while coasting. I have fixed boost leaks so they are minimal, and shouldnt afect the idle. the other thing the car does is if you creep forward two or three times like in a drive through it stalls out really annoying any thoughts. Thanks for looking
Old Jan 20, 2013 | 08:49 AM
ak47po's Avatar
Is this an Evo,or S2000?
Old Jan 20, 2013 | 08:50 AM
fastyouth1313's Avatar
Possible IAC going out.
Pull it out, it's under the TB and its 3 screws.
Clean/inspect it. Also check the the rubber gasket.
Old Jan 20, 2013 | 09:02 AM
latreille's Avatar
Sorry evo 8 2003 I have thrown 3 different iacs at it and it still does it ,no leaks at the iac seal small leak at the mill spec throttle shaft though and i mean small.
Old Jan 21, 2013 | 03:44 AM
latreille's Avatar
ttt
Old Jan 21, 2013 | 04:44 AM
Hitmachine101's Avatar
have you checked the maf? if not and you take a look at it and its covered in oil/residue from a k+n filter or possible blow back from the turbo then that might be your issue, mine was covered with crap when i got my evo, the guy never put a catch can on the car so the intake was still hooked up to the crank blow by and thus everything was coated in oil
cleaned it out with crc and all set normal idle and no issues at all
Old Jan 21, 2013 | 05:18 AM
latreille's Avatar
I already cleaned that. Thanks
Old Jan 22, 2013 | 12:43 AM
uamafioz's Avatar
my evo does the same, and when you turn your steering wheel while the car is not moving it will idle 1200rpms,,, my evo does that because of the tune, and the steering wheel part i think thats just how they are all...
Old Jan 23, 2013 | 02:14 PM
latreille's Avatar
No one, the stalling is really annoying.
Old Jan 23, 2013 | 02:58 PM
AIEvo9MR's Avatar
Please explain further. What exactly happens before it stalls? Do any lights come on? Does it make any sounds? What kind of mods do you have? Have you changed anything recently?
Yes its normal for your RPMs to go up when your A\C turns on or you move the steering wheel. They're driven by the crank and the engine compensates by increasing RPM.
Old Jan 23, 2013 | 02:59 PM
OfaceGrimmins's Avatar
By chance is your defrost on when the idle issue acts up?
Old Jan 23, 2013 | 05:46 PM
latreille's Avatar
My mods are limited to short route ets intercooler piping light weight flywheel and exhaust. I replaced the iac 3 times with used ones and it still stalls. I do not have evo scan to park the iac and set the bis screw. As for before it dips low it seems fine but if i try catch it takes a second for throttle to catch up. or else it stalls. I put an evo 9 bob on it as well. I just want it to stop stalling.
Thanks
Old Jan 23, 2013 | 06:25 PM
AIEvo9MR's Avatar
Question. When you were replacing the Idle Air Controller (IAC), did you happen to move, adjust, damage in anyway the Throttle Position Sensor (TPS)? It's the sensor above the IAC and is on the side on the throttle body.
Old Jan 23, 2013 | 06:31 PM
AIEvo9MR's Avatar
If you have a volt meter, you can determine if both have the correct values and adjust if necessary. Hopefully it eliminates your stalling.
File Type: pdf
Old Jan 24, 2013 | 04:35 AM
latreille's Avatar
Ive done that already. Thanks
