Please Help!!! Still smoking evo...
Old Jan 25, 2013 | 09:19 AM
thee stig's Avatar
I've been having this problem for quite some time now and basically what happens is when im on full throttle for more than a few seconds then when i lift off smoke comes out of the exhaust. i originally removed the vacuum lines off both the pcv and the intake and just let them vent to atmosphere. i did this hoping that there was some blow by and this reduced the smoking issue hugely but there was still some slight smoking after a wot pull. I just replaced the pcv and re attached all the vacuum lines and now there is more smoke then ever. It's a legit smoke screen now. i have a catch can on the line coming of the valve cover on the bottom right hand side and there was about a 1/4 of a quart of oil in the can accumulated over the last 6 months or so. The car has the stock ix turbo and on e85 running 25psi. The turbo has no shaft play, but i did once notice there was some oil puddled on the intake side of the turbo when the vent off the valve cover was hooked up to the intake. Does the turbo need to be rebuilt? Doesn't make complete sense to me due to when all the vents off the valve cover are disconnected there is only light smoking after wot. There is no smoke at all under normal driving. Any advice is welcome. Thanks.
Old Jan 25, 2013 | 09:48 AM
evokid511's Avatar
do you have an air/fuel gauge?
Old Jan 25, 2013 | 09:49 AM
WikdEvo's Avatar
How many miles? Smoking under boost alone would lead me to think turbo seals. Also seems like you are getting a lot of blow by. Ever done a leak down test or compression check?
Old Jan 25, 2013 | 09:53 AM
thee stig's Avatar
The car has 45000 miles on it. It doesn't smoke while under boost, but rather when i lift off after being on boost. Any ideas what would be causing that much blow by, and i haven't done a leak down or compression check. Do you think its something i should have done?
Old Jan 25, 2013 | 09:54 AM
thee stig's Avatar
No afr gauge. Car was tuned middle of last year with good afr's.
Old Jan 25, 2013 | 09:57 AM
WikdEvo's Avatar
Doesn't mean that it can't change. Engines don't always operate the same as when it was tuned. Plugs foul, atmospheric changes, bad gas, etc. etc.
Old Jan 25, 2013 | 11:06 AM
thepoint4life23's Avatar
Sounds Like Blow by to me. may want to do a leakdown test
Old Jan 26, 2013 | 07:36 PM
slimjim1804's Avatar
Odd it smokes after you get off of it. subscribed for updates.
Posted from Evolutionm.net App for Android
Old Feb 6, 2013 | 03:06 AM
SLVRcarbonEVO8's Avatar
Valve seals maybe?? I'm
Battling the exact same problem but mine smokes when it first starts too and under vacuum after a pull.. 4 shops have told me either rings or valve seals. Since my motor only has 10k I doubt it's rings. Just some more ideas for you
Old Apr 16, 2013 | 04:58 PM
EvilTechnology's Avatar
Mine started doing the same thing after a pull, lasted about 15 seconds after I dropped down to 4th on the highway and wailed on it.
Old Apr 16, 2013 | 07:54 PM
evox4b11turbo's Avatar
Im thinking its ur turbo seals. Think about it. When your under boost the compressor turbine side is under pressure pushing it to the exhaust side.. Well when you let off the throttle its opposite. Now vacuum is on the compressor side pulling the wheel back... Will happen when the engine is under high vacuum (decel, shifting, (cruising but not as much)
If you get a chance take off your intake and see if you have in and out shaft play, not up and down..
Also, you can take off your manifold to see if you have oil coming off your valve seals. If it doesn't look anything like this then its probably your turbo seals.
This is what mine looked looked like before i replaced the valve seals.
plan:b
Dec 25, 2015 09:07 AM
SeahawksOilers
Apr 26, 2014 12:40 PM
ottoman
15
Dec 14, 2011 12:32 PM
evokyle
Feb 15, 2011 01:54 PM
sykou
Lancer Aftermarket Forced Induction Tech
45
Jan 22, 2009 12:39 AM
