Help! AMS VSR intake manifold? map sensor
Old Jan 30, 2013 | 06:09 PM
christian_21's Avatar
Hi,im trying to install the AMS VSR intake manifold into my car but ir has no spot where i can put the map sensor. how do i put the map sensor into the manifold. thanks
Old Jan 31, 2013 | 07:09 AM
Andrew@AMS's Avatar
The map sensor cannot mount directly into the VSR intake manifold as there is no prevision for it. If you are using a stock style MAP sensor for tuning such as the Omni power unit, then you will need a map sensor adapter so that you can run a vacuum line directly to it.
Back when the VSR was first designed, there was no after market stock MAP sensor to use. Everyone used the AEM map sensors or other similar MAP sensors that did not mount to the intake manifold as they only required a vacuum source run directly to them.
The new F1 Intake that we have does have a provision for a stock style MAP sensor to be used as the Omni power and other after market higher reading MAP sensors have become widely used now for tuning.
Please let me know if you have any other questions.
Thanks
Old Jan 31, 2013 | 06:51 PM
jessmanEVO's Avatar
I've got a map sensor adapter if you're interested.
Old Feb 1, 2013 | 11:26 AM
Thanks Andrew ill let you know if i got more question i appreciated
Old Feb 1, 2013 | 11:27 AM
I just bought a map sensor adapter damn i i should of check here first. Sorry but thanks
ilikeppie
Sep 4, 2014 12:37 AM
gr8stevo
May 4, 2014 08:44 PM
High_PSI
Apr 9, 2014 11:34 AM
AMS
Automotosports - Illinois
46
Apr 18, 2013 01:50 AM
