AMS VSR Intake Manifold Install Questions
Old Mar 18, 2014 | 09:32 PM
High_PSI's Avatar
I just picked up an AMS VSR with a stock ported throttle body. Install brings two issues.
I actually run an AMS Piping kit yet this thingy won't line up. I called AMS and they suggested just buying a new upper ic pipe for $400+tax+Shipping. Is their an easier way to route the piping without breaking the bank?
Second is the EGR, or lake there of it's completely deleted. I still run an oem ecu so it'll throw a code instantly. Can that be flashed out?
Thanks guys.
Old Mar 19, 2014 | 01:18 PM
High_PSI's Avatar
Anyone?
Old Mar 20, 2014 | 01:46 PM
xXANCHORMONXx's Avatar
yes a remote tuner can delete it in the ecu.
As for the pipiping mayebyou can use another coupler for that joint.
Old Mar 20, 2014 | 06:27 PM
High_PSI's Avatar
The Guys at AMS are trying to sell me another $400 pipe, any idea what kinda coupler?
Thanks.
Old Apr 5, 2014 | 06:44 AM
FX11's Avatar
EGR can be flashed out on stock ECU
And I actually had to cut my pipe and had to reweld it. I cut it myself and paid $40 to have the aluminum rewelded to my specs.
Old Apr 7, 2014 | 09:55 AM
High_PSI's Avatar
That's what I heard, AMS keeps trying to sell me a new pipe for $450, seems to be their game plan.
Old Apr 7, 2014 | 02:18 PM
jrainwater's Avatar
Google "hump coupler". It should serve this purpose and work with your current set up. No need to drop more $$$$. AMS, lol.
Old Apr 8, 2014 | 07:29 AM
High_PSI's Avatar
Who is "Coupler" and it seems this would be NSFW so maybe wait till I get home?
Old Apr 8, 2014 | 09:44 AM
epiphanysfi's Avatar
coupler is an attachment from one hose type connection to another. Hence to couple them together. Best way is what one user already stated. Cut and extend unless you can find a coupler that could reach your intake.
The only thing bad about using a rubber coupler is that if there is no tension to keep it open the coupler could end up collapsing which would significantly restrict airflow to your engine. Its better off just getting some aluminum piping and extending what you already have by going to some welding shop or exhaust shop.
Old Apr 8, 2014 | 03:42 PM
jrainwater's Avatar
http://m.ebay.com/itm?itemId=191077526658
This, I don't see the need to weld or anything like that. This will work and will seal and does not leak. They're made specifically for your needs. The link is for a 3" obviously you need a different size but the link is more so you can get an idea of what I am talking about.
Old Apr 9, 2014 | 11:34 AM
High_PSI's Avatar
So this will fit a AMS upper IC Pipe to an AMS VSR with a ported OEM Throttle body?
ilikeppie
Sep 4, 2014 12:37 AM
gr8stevo
May 4, 2014 08:44 PM
AMS
Automotosports - Illinois
46
Apr 18, 2013 01:50 AM
christian_21
Feb 1, 2013 11:27 AM
Colt4g63
Feb 10, 2009 11:31 PM
