Timing belt help
Old Feb 26, 2013 | 01:48 PM
VR4-EVO's Avatar
Originally Posted by Ev0ikon
Guess I'll keep waiting for that PM then.
Huntsville is a good drive away but if I get times away from the house (usually late on weekends) I'll come put that belt in time for you.
You didn't get it? I can see to others no problem. The car runs. It's been running in this state for awhile. So I can meet you somewhere. Don't want you to have to drive all this way.
Old Feb 26, 2013 | 02:29 PM
Ev0ikon's Avatar
It's scary if you are driving it around with that much timing off. It my not be the case then.
I have a friend (with DSM cars that lives right off I65 in Gardendale so you could meet me there if you want. Otherwise I could be in Trussville area most of this coming weekend.
FYI: my screen name has a "zero" and an "o" in it.
Old Feb 26, 2013 | 03:31 PM
evotuner04's Avatar
15 Year MemberLikedLoved
click on his id on one of his posts and scroll down to where it says private message, click and message. theres no way to mess up the name that way.
Old Feb 26, 2013 | 04:09 PM
VR4-EVO's Avatar
That's exactly what I did. Except he still didn't get it. I guess it's the time zone
Old Feb 26, 2013 | 04:53 PM
evotuner04's Avatar
Thats weird :/
maybe a mod will look into in case theres another reason
Old May 9, 2013 | 08:24 PM
VR4-EVO's Avatar
Just to update you guys, it was one tooth off at the crank. She's purring good now .
Thanks for your help!
Old May 10, 2013 | 08:12 AM
barneyb's Avatar
Just a note to belt installers - if the belt is going to jump during belt install, it occurs at the crank sprocket.
Old May 10, 2013 | 09:55 AM
ProPilot04's Avatar
Why/what makes you say that?
Old May 10, 2013 | 12:33 PM
barneyb's Avatar
If you have a tool that holds the cam sprockets in place (slips into the teeth between them) then no problem. But, I'm guessing most DIY don't. In that case the valve spring pressure is great on the belt and the place it slips is at the crank sprocket.
When I was doing my 60K I had the new belt marked (paint marks on the belt that had to match a paint mark on each sprocket for correct timing) and while adjusting the tension by way of the eccentric pulley I'd hear a thunk. Looking around I'd see the belt had jumped at the crank sprocket. This happened two times while I was messing with tension. If the belt and sprockets hadn't been marked I likely would have been in the same situation as the OP.
Old May 10, 2013 | 12:59 PM
ProPilot04's Avatar
Interesting... do we have any thoughts on how to prevent this?
I'm about to do my 60k after I get my transmission back in, and my axles rebuilt this next week.
Old May 10, 2013 | 02:25 PM
barneyb's Avatar
Turn the engine until all the timing marks line up. Paint marks on each sprocket and out onto the belts. Transfer the marks to the new belts. Buy the tool I mentioned above for the cam sprockets and insert it before removing the old belt. By doing the above you should have no problem.
Old May 10, 2013 | 02:37 PM
SilverShadow03's Avatar
This is the tool set I bought for $50...it includes the tool barneyb is referring to.
Timing Belt Tool Set
Old May 12, 2013 | 12:30 AM
uamafioz's Avatar
ones you remove the timing belt cover, there are two nicks marked behind it,, they are super tiny and hard to see, you gotta get close to see them, and then each pully has the mark as well, so match them up and put the belt on.
liass44
11
Nov 18, 2016 07:05 AM
Eno-Evo
14
Aug 4, 2015 08:36 PM
DonMitsu
North Texas Evo Club (NTEC)
Mar 18, 2011 05:27 PM
Evo_Tom2005
May 21, 2008 01:11 PM
gamma500
12
Nov 11, 2005 04:22 AM
