aftermarket BBS lugs
Old Feb 28, 2013 | 01:16 PM
slc_evo69's Avatar
Traded for OEM Evo BBS, I want to powder coat them and do an aftermarket colored lug. But from what I understand, you can't run an aftermarket lug on OEM wheels because they ruin the wheel after sometime.
I've searched but haven't found anything, does anyone know of a good aftermarket lug that is compatible with OEM BBS?
THANKS!
Old Feb 28, 2013 | 01:35 PM
Ev0ikon's Avatar
Spray paint the lugs. Problem solved.
Old Feb 28, 2013 | 01:44 PM
clubEVO93's Avatar
^ doesn't answer the question. Im also curious to this!
Old Feb 28, 2013 | 02:08 PM
mrboost05's Avatar
its not that they will ruin the wheels its that its not safe there are a ton of threads in the suspension fourms with that said ive run aftermarket lugs on my oem bbs wheels and dident have any problems they were loose once but that could have been from me using my impact or something.
https://www.evolutionm.net/forums/ev...ck-wheels.html
Old Feb 28, 2013 | 02:11 PM
llDemonll's Avatar
Unless you are running shank-style aftermarket lugs, they are not safe and not intended for use on the BBS wheels
Old Feb 28, 2013 | 03:33 PM
ProPilot04's Avatar
Cuz colored lugnuts are more important than your wheel falling off.
Old Mar 13, 2013 | 06:37 PM
J-Evo9's Avatar
would love to know the answer too
Old Mar 13, 2013 | 07:13 PM
llDemonll's Avatar
there is an answer. run shank-style lug nuts. that's it
Old Mar 13, 2013 | 07:48 PM
Awdtsier's Avatar
^its as simple as that.
wowzers
25
Sep 7, 2019 04:03 PM
farm_use
Apr 8, 2016 04:27 AM
butters149
Mar 7, 2014 12:18 PM
cleudson
Oct 4, 2013 07:47 AM
evonky
Apr 13, 2011 08:44 PM
