Car "dieseling" after ignition off
Old May 2, 2013 | 04:36 AM
The-Evo's Avatar
Its funny that you mention that, because that is exactly what I think it is also. There might be a possibility that the AEM is going bad. But I haven't heard any one talk about the new series 2 ecu's going bad yet.
Originally Posted by donzilla2004
Last time I ran into an issue like this it was with a car that wasn't a mitsu, and was bone stock, the injector driver in the pcm was going bad, any chance the aem computer is going bad?
Old May 2, 2013 | 06:52 AM
donzilla2004's Avatar
I wonder if AEM would be able to tell if the ecu was sent to them. For all we know it could be a bad solder in the ecu?
Old Dec 21, 2013 | 05:53 PM
ezzey's Avatar
I still haven't come up with a fix. I don't know if it's the ecu. But the weird thing is, the dieseling never occurs if cars only little warmed up. It has to be fully warm which makes me believe that injectors and ecu is ok. Not sure what the issue is but still looking for a fix.
Old Dec 21, 2013 | 09:19 PM
cfdfireman1's Avatar
post #2 said it.
Originally Posted by barneyb
The old carburetored cars would do this because as long as the engine was turning the carburetor would feed gas. Fuel injection cured this. Turn off the ignition and the injectors quit working - unless they are leaking.
Next question is what's igniting the fuel? Are the injectors leaking or is your AEM telling them to open and sending a signal to your coils?
Old Dec 22, 2013 | 03:59 PM
Booztd3's Avatar
sounds like a driver issue
Old Nov 26, 2014 | 03:46 PM
Titish's Avatar
Helppp
Am having the same issue with aem s2 and fic 1450..did u find the solution?
Old Nov 27, 2014 | 01:28 AM
The-Evo's Avatar
AEM was fine. I sent in my FIC 1650's and they were all out of the normal parameters. So they gave me the new revised 1450's for better drivability. Car drives fine now. Doesn't do that dieseling issue. I think running q16 through them caused them to act up. Also, I noticed it only happens after long drives and if I turn off the car too quickly without letting it idle for a few secs. Hope that helps. A good tune could help also. It's caused when there is too much fuel still sitting on the Pistons.
ghozt
Sep 14, 2016 07:04 AM
ezzey
Jul 19, 2016 04:48 PM
mRVRsport
24
Jun 28, 2016 08:14 AM
Ztevo93
Lancer Troubleshooting
Jan 12, 2015 11:34 PM
evoo8899
Jul 26, 2011 05:50 PM
