Help please
Old Feb 28, 2013 | 05:36 PM
Evolution8.5's Avatar
Help please
Evo 9 cranks but won't start I have fuel spark and compression I'm thinking cam sensor because as far as I know the crank sensor would kill fuel and spark anyone have any other ideas to check and or previous experience with this problem car is on stock Ecu with only a turbo back and intake I have checked all Ecu fuses as well and all are ok I'm out of ideas. Please help
Old Feb 28, 2013 | 07:03 PM
barneyb's Avatar
In your sig you say Evo 8 with full swap to 9. Is this the car we are talking about?
Old Feb 28, 2013 | 07:45 PM
Yes it's a 04 shell with evo 9 engine trans transfer case harness Ecu and interior
Old Feb 28, 2013 | 07:46 PM
I don't think it's swap related as Iv put over 40k on it since the swap
Old Mar 4, 2013 | 02:40 PM
1998GSX's Avatar
You must have fuel and spark to start. You said you have those things. So I would start to check your timing, are your plugs in the right order. Check your CAS as well.
Its probably just some minor thing you forgot.
No smoke coming out while its being cranked? If water is getting into the cylinders due to head gasket leak then it wont start either.
Just start from where you finished doing your work and work backwards.
Let us know what you find.
Old Mar 6, 2013 | 08:46 PM
05blue8's Avatar
If you were flashing it you could have blown fuse 1, that will cause the problem you're describing also. I've had my fuse 1 blow a few times for odd reasons but it's generally when I'm flashing my car and the laptop hiccups and loses connection....that will blow it every time
ezzey
Jul 19, 2016 04:48 PM
xceler8rob
34
Jul 17, 2016 12:57 PM
lostsoulsevo
Nov 23, 2014 12:52 PM
REV.olution
Aug 24, 2013 08:54 PM
jason42003
68
Nov 6, 2012 08:17 PM
