blown headgasket....fml
Old Mar 10, 2013 | 12:30 PM
RussellDaniel's Avatar
Originally Posted by adriano_917
Not really!
lol what do you mean? P0234 has nothing to do with fuel. Its a overboost code.
Old Mar 10, 2013 | 12:36 PM
meckert's Avatar
Yeah, 28-30 psi on stock block and stock headgasket, no headstuds-- well what did you think would happen? Lucky it lasted as long as it did. GL.
Old Mar 10, 2013 | 01:31 PM
do you guys read my signature??? My motor is built. I have arp headstuds.
Old Mar 10, 2013 | 04:05 PM
Runker's Avatar
Couple SR20's will pull a premium right before race wars.
Old Mar 10, 2013 | 04:28 PM
huh?
Old Mar 10, 2013 | 05:51 PM
SmurfZilla's Avatar
Have you been missing the Fast & the Furious quotes throughout your thread. lol.
Looks like it was mishimoto tires.
Old Mar 10, 2013 | 06:14 PM
Raptord's Avatar
You don't have a signature.
Old Mar 10, 2013 | 06:51 PM
boostedwrx's Avatar
OK good, it's not just me that doesn't see one..
Old Mar 10, 2013 | 06:59 PM
That's wierd my signature normally pops up. Don't know why it's not now.but yes the motors built running e85. The arp head studs obviously weren't doing it so I ordered some better headstuds from map. No I wasn't aware of the faf quotes.
Old Mar 10, 2013 | 09:02 PM
Kian's Avatar
Originally Posted by luis!
Sucks to hear. At least you didn't blow the welds off the intake or fry any piston rings.
Yeah...true
what headgasket were you using?
Spirit. Thank you. Thank you for direct-port nitrous injection, four-core intercoolers, ball-bearing turbos, and titanium valve springs. Amen.
Old Mar 11, 2013 | 12:47 AM
SmurfZilla's Avatar
I saw your sig. Weird. Some posts show it. Some don't.
Old Mar 11, 2013 | 05:25 AM
Fast_Freddie's Avatar
Veteran: Navy
Make sure you check your injectors for gunk while you have everything apart... that may have been the issue all along...
Old Mar 11, 2013 | 06:58 AM
The injectors cause overboost? The code is P0234. Im using OEM headgasket again, thats the best.
Old Mar 11, 2013 | 07:41 AM
Kian's Avatar
Haven't ever had a problem with my oem, I'm trying a cosworth and map head studs with the new build. Well see how that works out
Old Mar 11, 2013 | 07:56 AM
that's what im gonna use. Getting rid of my arps and going with map headstuds. The cosworth and oem are the best to use from what I've been told.
