blown headgasket....fml
Old Mar 11, 2013 | 08:17 AM
  #31
mdsevo06's Avatar
You know you still owe me a ten second car...
Old Mar 11, 2013 | 08:29 AM
  #32
wazzelby's Avatar
Ok, it's early and I haven't had my coffee yet but if you are using a MBC, why are you getting an overboost code? Have you checked your MAP sensor? are you still using the stock map sensor? Also, what are you tuned on, Tephra, stock?
Old Mar 11, 2013 | 09:01 AM
  #33
RussellDaniel's Avatar
that's a very good question. Yes im using tephra. The issue at first I thought it was plugs before I checked the code. Then I thought it was the wastegate. After I turned the boost all the way down and it held 20 I knew it wasn't the wastefate. The only thing I can think of is the boost controller failed.
Old Mar 11, 2013 | 09:07 AM
  #34
Grimgrak's Avatar
Did you log knock counts?
Old Mar 11, 2013 | 09:16 AM
  #35
no buy im sure it was knocking lol. Drfinetly misfiring till I turned down the boost
Old Mar 11, 2013 | 01:40 PM
  #36
adriano_917's Avatar
Originally Posted by RussellDaniel
lol what do you mean? P0234 has nothing to do with fuel. Its a overboost code.
That you didnt specify what injectors and fuel you were using!
Old Mar 11, 2013 | 03:01 PM
  #37
the fuel and injectors are completely irrelevant. Its a boost issue.
Old Mar 11, 2013 | 05:09 PM
  #38
Anyone have a clue...again the code is a boost issue not a fuel issue.
Old Mar 11, 2013 | 05:46 PM
  #39
Okay let me go back, I didnt know if you were stock or not and boosting 28 to 30psi. So I assumed that you were trying to boost what I just mentioned and you had boost/fuel cut. If you went back to 20psi and the car ran fine, then you up it to 28psi and the problem came back. What does that tell you ? Read this thread
https://www.evolutionm.net/forums/ev...-question.html
Old Mar 11, 2013 | 06:06 PM
  #40
<p>
Okay let me go back, I didnt know if you were stock or not and boosting 28 to 30psi. So I assumed that you were trying to boost what I just mentioned and you had boost/fuel cut. If you went back to 20psi and the car ran fine, then you up it to 28psi and the problem came back. What does that tell you ? Read this thread</p>
<p>&nbsp;</p>
<p><a href="https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain/232586-fuel-boost-cut-question.html" target="_blank">https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain/232586-fuel-boost-cut-question.html</a>
</p>
<p>&nbsp;</p>
<p>it tells me that something is wrong considering when I was tuned I was spiking 33 psi. I didn't really get a chance to adjust it anymore because somehow the headgasket blew. Just a freak situation. My boost cut is set at 37psi so two turns with the boost controller after hitting 28 psi should not have caused possibly a 40 psi spike.</p> I read it...im gonna try and get it down to my tuner whenever i get the headgasket fixed. I'll post the updates of what the issue is.
Old Mar 11, 2013 | 06:18 PM
  #41
Okay! you spike 33psi and hold 28psi right? After 2 clicks on the mbc it spiked 40psi. The problem relies on the mbc(possibly a hose)or wastegate.
Old Mar 11, 2013 | 06:25 PM
  #42
spike 33 hold 30. I checked the wastegare its good it held 20 like a champ.i looked at the hoses didn't see any splits im thinking something's up with the damn hoost controller.
mrfred
Jan 6, 2024 09:43 PM
mrfred
Dec 31, 2023 08:49 AM
OherrOderr
09+ Ralliart Show and Shine
28
Dec 18, 2012 09:57 PM
goodhart
Jul 19, 2011 03:51 AM
Rustyreno
For Sale - Cars For Sale
Jan 12, 2009 06:47 PM
