Wiring harness problem!!!???
Old Mar 9, 2013 | 08:58 AM
ReignMan24's Avatar
so ive run into the issue while tuning with tscomp that the grimmspeed 3port will not function...we've already replaced it with a brand new one and it is still not working. is there a possibility that part of the harness is bad, becuz when we tuned before last yr, the 3 port worked fine. plz help guys, this is holdin me back from really doin nething.
Old Mar 9, 2013 | 11:58 AM
ReignMan24's Avatar
neone? sumone has to have sum kinda of recommendation
Old Mar 9, 2013 | 12:20 PM
10isace's Avatar
Did you test the controller? I'm not sure, but I bet you can do something like this:
Old Mar 9, 2013 | 12:55 PM
ReignMan24's Avatar
the thing is i have a brand new grimmspeed and im thinkin its not getting enough power from the wiring harness that comes from the car...
Old Mar 9, 2013 | 03:00 PM
ReignMan24's Avatar
anyone else?
Old Mar 9, 2013 | 09:50 PM
ReignMan24's Avatar
anyone?
Old Mar 9, 2013 | 10:49 PM
bsphillips's Avatar
If you don't think its getting enough power from the car take a volt meter to it and see what its receiving.
Old Mar 10, 2013 | 12:45 AM
ch53avitech's Avatar
Meter for power at pin 1 and a ground at pin 2.
FYI the ground is integral to the ECU through pin 11 in connector C-121. Hopefully you don't have to do too much digging to find your problem.
Old Mar 10, 2013 | 07:55 AM
ReignMan24's Avatar
i really appreciate the input guys..is this common that the solenoid harness would fail, cuz ive searched and ive found nothin. and the fact that it worked perfectly fine before is confusing the hell out me
Old Mar 10, 2013 | 11:56 AM
ReignMan24's Avatar
so i took a volt meter to the harness...its getting the correct amount of power, so im pretty stumped rite now
Old Mar 11, 2013 | 04:50 AM
ReignMan24's Avatar
bump..
Evo10Gsr
Mid-Atlantic Region
Jun 22, 2014 10:20 AM
maxroach
Feb 11, 2014 04:12 PM
Stoneman
Mar 11, 2013 01:37 PM
a4rontran
Feb 28, 2013 05:44 PM
