ECU Problem????
Old Feb 24, 2013 | 06:59 PM
a4rontran's Avatar
ECU Problem????
Hello,
Recently, I'm running into trouble with the 3 port issue. Well my car was tuned at 25 psi peak and tapper to 22 psi with 3 port. Now, the car does low boost at 14.5 psi from start and spike at 21 psi while connecting to the 3 port. So we switch the new 3 port to see if that solve the problem; however, the car acts the same. Then they switch to MBC, magically it works. The car boosts at 25 tapper to 22psi. They told me that the problem can be from my ECU or the wire harness that cause problem. Would you please tell me what do you think the problem is? I want to see the other opinion about it.
I also test the power output for the plug that connect to the 3 port, it shows that plug does have power.
Thanks
Old Feb 25, 2013 | 11:21 AM
a4rontran's Avatar
anyone?
Old Feb 25, 2013 | 12:19 PM
Anarchy99's Avatar
sounds like you are hooking up the ports wrong on the 3 port or you are knocking and cutting boost as a safeguard
Old Feb 28, 2013 | 05:44 PM
a4rontran's Avatar
Update:
Today i found out that the connector that plug to the port has no ground. Is there a way that I can trace where this wire get short at?
Thanks
a4rontran
For Sale - Cars For Sale
Jul 29, 2013 02:53 PM
egis
Jul 12, 2013 08:01 PM
abosoxfan4life
Cobb AccessPORT
15
May 3, 2013 08:30 PM
a4rontran
Mar 13, 2013 07:54 AM
a4rontran
Feb 9, 2013 03:06 PM
