how safe is driving without acd pump evo 9
Old Mar 30, 2013 | 07:35 PM
jrainwater's Avatar
It's 100% fine to drive with the pump off the car. The guy who invented the rebuild kit drove his around for 40k miles with it off the car. Like a poster said it just makes it an open diff at that point. I love quick posters who love to comment on things they know absolutely nothing about.... Fake know it alls.......
Old Mar 31, 2013 | 08:33 AM
jameelrose's Avatar
Originally Posted by steven121
Thats why I bought an 8
has an 8. has ACD.
Old Apr 24, 2013 | 08:29 PM
xi's Avatar
xi
I think the ACD's going in my RA. I intermittently get the chime then it goes away on the next start. It seems to be happening on the warmer days.
What exactly happens to the driving characteristics when the ACD stops working and the center diff starts functioning like an open diff?
Old Apr 24, 2013 | 08:38 PM
ecktt's Avatar
Not sure about only ACD but when i lost my ACD/AYC pump, the car is lazy out of corners, didn't feel as sharp and doesn't drive like a "point and power" setup anymore. I should really fix my ACD/AYC pump.
Old Apr 24, 2013 | 08:42 PM
Raptord's Avatar
Originally Posted by ReidFletcher
No pump=no fluid. Damage will ensue.
Originally Posted by rmorr79
Do not drive without the acd pump.
Originally Posted by Sil'vr-Boi6
+1. What everbody just said ...your clutch pack within the transfercase will fry less than a mile of driving.
The 3 of you are wrong.
Originally Posted by nollij
Isn't the pump just supplying the hydraulic pressure to the clutch pack? Without that hydraulic pressure, there is no lock up and you would be driving with an open differential.
As for the fluids for the ACD pump, Wouldn't the gear oil in the TCase be what is supplying the fluids for the clutch pack (if the clutch pack is even submerged in the TCase fluids)?
If this is the case, it would just be like driving around with an open differential.
This man speaks truth. The ACD pump has nothing to do with lubricating the TC, it is only used to allow locking of the TC. The car will drive like an open-diff car, but nothing will be damaged. I drove on a dead ACD pump for 2-3 months (including one track day) and my tcase is just fine.
Old Apr 24, 2013 | 08:55 PM
Viegasjuice's Avatar
Does the handling get much worse with a bad pump?
Old Apr 25, 2013 | 06:07 AM
Raptord's Avatar
I did notice a small difference on track but it wasn't enormous.
Old Apr 25, 2013 | 06:37 AM
blowngasket's Avatar
When my ACD was acting up i had WAY more oversteer in corners, Seemed like it wasnt locking up quite well At all, id try to compensate for it then BAM it locks it was hesitant and id oversteer but then when i did it would lock.no ive gone with a non ACD TCase, This thing handles like a dream.
Old Apr 25, 2013 | 06:54 AM
boosted91t's Avatar
Originally Posted by jameelrose
has an 8. has ACD.
2003-2004 evo 8 = no acd
2005 evo 8 and 2006 evo 9 = acd
Old Apr 25, 2013 | 07:10 AM
NOMIEZVR4's Avatar
I have an ACD pump, actually a whole ACD setup for sale!
Old Apr 25, 2013 | 09:24 AM
xi's Avatar
xi
Way more oversteer you say...
Old Apr 25, 2013 | 09:34 AM
Yes, i took a corner real hard car kicked out easily i compensated for the oversteer and when i did it freaking locked causing it to come back and almost lose it.
It was like WAY oversteered into and correcting the turn, untill it locked up.
Now thats its non ACD its Way different for me, it dead on correct now and does what its supposed to do, but there is a quaife Front diff in it too
Like it didnt slip correctly thru the turn, then lock up late after the fact.
I had a serious issue with my Tcase thou, My Trans to CV shaft, the one that goes into the trans to the Tcase was SPUN HARD into the Center Differential, like it spinned at a dramically different Rate then the Center diff.
It was totally chewed up.
Old Apr 25, 2013 | 09:47 AM
xi's Avatar
xi
I think my ACD pump is gone, not just on and off but it's not working 100%. The message comes up every time I start the car now, was intermitent before when it was colder out.
Last night picking up my gf from class, I was going into the BQE and if anyone knows the atlantic avenue onramp, it's freaking near the end of a 45 degree downhill corner on the highway. Think like, putting an onramp entrance right in the middle of the corkscrew at laguna seca. So I floored it going on and I felt the back end slip out and I was like, odd.. I never got any oversteer like that before.
Old Apr 25, 2013 | 10:04 AM
Exactly, mine was more extreme thou going into the turn when i first noticed it, i almost lost control of the dam thing. AND I NEVER LOSE IT. lol
Old Apr 25, 2013 | 11:29 AM
xi's Avatar
xi
So lost of ACD pump = SUPER FUN MODE.
