how safe is driving without acd pump evo 9
Old Mar 13, 2013 | 02:44 AM
lomsa's Avatar
Hello guys,
I have a question: I have removed acd pump, how safe is driving without it? Can it damage something? transfercase or something else?
Old Mar 13, 2013 | 08:28 AM
ReidFletcher's Avatar
No pump=no fluid. Damage will ensue.
Old Mar 13, 2013 | 08:41 AM
KostyaEVO6RS's Avatar
will def
Old Mar 13, 2013 | 08:51 AM
mdsevo06's Avatar
You have to modify the TC if your going to remove the pump, you can't just remove the pump.
Old Mar 13, 2013 | 09:13 AM
rmorr79's Avatar
Do not drive without the acd pump. read this for some good info https://www.evolutionm.net/forums/ev...everybody.html
Old Mar 13, 2013 | 10:29 AM
steven121's Avatar
Thats why I bought an 8
Old Mar 13, 2013 | 10:31 AM
blowngasket's Avatar
and thats why i switched over from a acd crap case to a non acd Built Tcase.
tha was a good read, cool to see how opinons were in 2005 on the acd system.
to the OP, do your self a favor and ditch the ACD system.
Old Mar 13, 2013 | 11:01 AM
Sil'vr-Boi6's Avatar
+1. What everbody just said ...your clutch pack within the transfercase will fry less than a mile of driving.
Old Mar 13, 2013 | 11:15 AM
nollij's Avatar
Isn't the pump just supplying the hydraulic pressure to the clutch pack? Without that hydraulic pressure, there is no lock up and you would be driving with an open differential.
As for the fluids for the ACD pump, Wouldn't the gear oil in the TCase be what is supplying the fluids for the clutch pack (if the clutch pack is even submerged in the TCase fluids)?
If this is the case, it would just be like driving around with an open differential.
Old Mar 13, 2013 | 11:48 AM
lomsa's Avatar
Thanks guys, pump is broken so i'm gonna change it.
Old Mar 13, 2013 | 12:58 PM
casual's Avatar
how long did it take to remove the pump and was it difficult?
Old Mar 13, 2013 | 01:52 PM
rongdoer's Avatar
My acd throws the three lights when it's the hottest of summer days, but I've been driving with it like that for 2 years with no problems.
Old Mar 13, 2013 | 02:11 PM
RussellDaniel's Avatar
I drove forever with bad acd pump
Old Mar 13, 2013 | 02:20 PM
gsr0801's Avatar
I've been driving about five years with all three lights on. The transfer case does wine a lot when it gets hot though.
Old Mar 13, 2013 | 05:19 PM
The acd pump only puts pressure on a Actuator with a seal on the clutch packs, the Tcase oil keeps em lubed. I say if the Tcase is whining ditch the ACD all together. If you really wanna keep it stock then replace the pump, BUT look at your rebuild options on that, if its the motor you could send that out to be fixed at a motor shop. Or in most cases its just the Pump housing plate Rusted and corroded.Its Very easy to rebuild, and pretty easy to take off and put on, just watch the line that threaded end can get knarled up quite easily.
LoL i still say ditch the acd thou,
