Opinions on my timing map
Old Mar 16, 2013 | 01:52 PM
steven121's Avatar
only question is timing, where should timing be around for
-during boost
-peak boost
-when boost drops.
peak boost 3500 rpms with evo 9 turbo, mods in sig
below is my pulls in 4th gear, I just need some input, I have read all pages of merlins tuning guide, it seems the only thing left out was how much timing for each category to optimize your performance, but i do realize every car is different
Old Mar 16, 2013 | 02:13 PM
blowngasket's Avatar
id get a new intercooler, Whats up with the knock counts @250 load and up
Old Mar 16, 2013 | 02:43 PM
evo8426's Avatar
Quick tip, only log the following items:
TPS, RPM, Load, KnockSum, Timing, Wideband, and AFRMAP
You are logging way too many things and it is slowing your logger down. With better resolution you may be able to see where exactly the knock is occurring and what is happening.
Too little timing causes knock just like too much timing. Your timing maps need to have smooth transitions ideally with no more than 3 degrees difference during spool up. Can you post up your timing map instead of the fuel map?
You need to inspect everything in the engine bay and along the rest of the exhaust looking for anything and everything that may possibly rattle. Loose and rattling parts will cause the car to pick up noise and interpret it as knock.
I would also recommend putting your mods in the first post instead of telling people to look at your sig. Sigs change over time and someone may stumble upon this thread and you no longer have the same mods or deleted the sig.
Old Mar 16, 2013 | 03:18 PM
steven121's Avatar
lol sorry man hahaha give me a second for the map
Old Mar 16, 2013 | 03:23 PM
steven121's Avatar
trying to figure that out. Eventually I will get a new intercooler, trying to save for honeymoon
  • I do log those things but it seems like it tries to log everything for some reason, I just edited the file to see what I needed, I deleted tps but I will have a better log tonight for yall to view
  • The 3 degrees timing rule I did follow through out the boost portion of the map
  • I will keep that in mind thank you
steven121
Lancer Aftermarket Forced Induction Tech
1720
Mar 11, 2021 08:41 AM
steven121
Oct 25, 2013 11:52 AM
steven121
14
Dec 11, 2012 05:53 PM
steven121
02-03 Lancer Show / Shine
13
Mar 2, 2012 03:12 PM
