Oil pan gasket?
Old Mar 18, 2013 | 11:47 AM
pls1968's Avatar
I bought the RockAuto oil pan gasket too. I will be giving it a try in the coming weeks.
Old Mar 18, 2013 | 12:17 PM
todd6027's Avatar
Originally Posted by Gordian79
spend $40 on mitsu rtv and you wont have any problems.Evo Oil pan are not designed to work with a gasket and will eventually leak.
good advice
Old Mar 27, 2013 | 01:28 AM
BkzProblem's Avatar
Wowww.. just my luck.. after i had to pull down he oil pan twice.. I wish i wouldve saw this sooner.. I hate scraping and grinding the old gasket off of the pan/ block.. this wouldve made my life soooo much easier...
Old Mar 27, 2013 | 05:01 AM
TommiM's Avatar
Next time try Loctite 7200. You spray it on the rtv and let it sit for a minute. Then just scrapes right off with no hassle.
Old Oct 6, 2013 | 10:27 PM
Evo8jpp's Avatar
Any word from the members that used the fel pro oil pan gaskets? Leak free or not?
Old Feb 21, 2014 | 06:42 PM
ace33joe's Avatar
In for review from actual users.
I am leaking oil from oil pan slightly, and interested in using one from Fel-pro if it works better than just grey Permatex sealant.
Old Feb 21, 2014 | 08:18 PM
jrainwater's Avatar
Eh, I doubt it works better. My oil pan was rusty from Chicago winters so I replaced it in august before the first snow. I used a medium bead of grey rtv around the pan when I put the new one on. There's a small lip on the oil pan you follow around making the little bead slightly on the inside of that lip as you go around. I don't see the advantage of the cork gasket and if anything I would think that would leak way before the grey rtv would. I know you asked for people who HAVE used the felpro gasket but I didn't think the other side of the coin could hurt. Especially since the oil pan bolts are super short to begin with and that felpro is kind of thick. Fyi I'm sure you know this but jic, there are different length bolts around the timing side of the engine.
Old Feb 21, 2014 | 08:39 PM
okevolutionVIII's Avatar
I've used the Felpro oil pan gasket for 2 years, no leaks.
Old Feb 21, 2014 | 08:48 PM
jrainwater's Avatar
Did you just torque to factory specs using that gasket? I'm just curious because the service manual torque specs are for rtv not a felpro.
Old Feb 22, 2014 | 10:31 AM
1UpMoto's Avatar
Originally Posted by fastyouth1313
I really don't think my pan is bent. What we did the first time was lay the grey RTV bead, them we smoothed it out. Waited 5 mins then bolted it to the block then it sat over night. Then put the engine and put oil in. It's just a small leak. Enough to have a few small drips.
Dont smooth out the bead, let the pan flatten it out when you bolt it on.
Old Feb 22, 2014 | 12:05 PM
jrainwater's Avatar
^^^^^^^^ I didn't smooth it out either when I did it. Just waited 10 minutes for it to start getting tacky and then bolted it up. Maybe that is where you went wrong.
mouseIX
31
Apr 8, 2016 08:15 PM
RalliMark
15
Dec 24, 2015 11:16 AM
Tiresomejunk
Dec 14, 2015 04:53 AM
NeveReveN
Jul 30, 2014 04:15 PM
MISHI
Nov 23, 2011 09:20 PM
