door lock cylinder replacement?
Old Mar 17, 2013 | 07:12 PM
blkmkIII's Avatar
How would I change this? Since I am looking to avoid changing all my ignition stuff for this.
Someone tried to break in with a screw driver so I need to replace the driver side.
Old Mar 17, 2013 | 08:10 PM
MRolla's Avatar
buy anew cylinder take it to a lock smith and have it recoded to your key
Old Mar 17, 2013 | 09:18 PM
blkmkIII's Avatar
thank you sir
Old Mar 17, 2013 | 09:28 PM
cwyteboi's Avatar
Recoded? A cylinder kit will come with all the pins required to fit your key and you can make sure it works before installing it in the door. It's just a mechanical lock and is quite simple. That's the easy part. The hard portion is fitting your arm and hand up in there to put it back in, PITA.
Adam Arthursson
Apr 3, 2016 12:09 PM
JonGonzo
Jun 27, 2015 12:49 PM
Lodus
Nov 6, 2014 08:00 AM
Eric30
Jun 27, 2014 11:42 AM
Mikebus7
15
Dec 29, 2011 10:00 PM
