question about wideband
i was just wondering if some one could get me some info on how do u read it and what are the right readings that it should have on the guage of a Innovate LC-1 Wideband. If some one could direct me on where i could find out the info on that?
at idle or cruising you want it to be at 14.5-15.3 which is the perfect air to fuel mixture. At WOT, you will want to be anywhere between 11.3-11.7 on pump... on meth you can run a little leaner.
the lower the # the richer you are, the higher, the leaner you are.
michael knight
Dec 28, 2013 01:58 PM
