Big problems after turbo install. Help please!
Hello all,
I recently installed an Evo 9 turbo on a buddies car. After we got everything cinched up the car turned right over. We shut it off after 3 minutes or so to inspect and ensure all was good with no leaks. After the inspection, I tried to turn the car over and it coughed and would not fire. It progressively got worse and now the car just cranks really fast as if there's no compression and wont attempt to do anything. Its getting fuel to the rail but the fuel pump doesn't sound like its priming on "key on." Also, the cam position sensor is broken and i swapped it out with the one from my car and it still does the same thing. I am going to do a compression test and check for spark later today but any insight ahead of time would be greatly appreciated.
Thanks in advance,
Rschanaman
Thanks in advance,
Rschanaman
If the car was running before the installation and it doesnt run after the istall, you messed up something. I know you already checked but check again and be thorough. The only things you need to remove for a turbo install are downpipe, manifold. o2 sensor & housing, maf pipe, water and oil lines, radiator & fan(makes it easier). If you're still on maf, is it plugged in cause ive seen people forget to plug it in.
I did the compression test and it all checked out. 180, 175, 167, 168. I checked for spark which is the problem. I've checked all the fuses and nothing is blown. I'm going to get a voltmeter when I get some more time and dig a little deeper.
does it crank over very easily? is that what you mean when you said with no compression? I would check you timing belt and balance shaft belt. my evo cranked over very easily, with no compression as you said, and it turned out to be my balance shaft belt had busted on me. poor timing for that to have happen!
Charging the battery is one of the first things we tried. Reversed boost lines don't keep a car from getting spark. I grounded a plug while the car was being turned over and it didn't light. I'm hoping there's not a short somewhere...
