cel flashes
Old Mar 28, 2013 | 08:20 AM
team714's Avatar
cel flashes
Just got tuned recently at rre. when i go from 60mph to 70mph in 6th gear my cel flashes like 4-5 times. i ask my tuner and he said it was no big deal. should i be worry? is it a misfire?
Old Mar 28, 2013 | 08:56 AM
gsrboi80's Avatar
Tuner enabled the CEL to flash when the car detects knock. You need to log the car a couple counts I wouldn't worry about but more than that in a high gear high load situation I would.
Log the car.
Fast blink or slow blink from the CEL???
Old Mar 28, 2013 | 09:12 AM
jager89's Avatar
Doesn't it also mean possiblility of damaging the cat? Too much fuel from a misfire. One of those emissions related things?
Old Mar 28, 2013 | 09:22 AM
evo8426's Avatar
I would go back and have them fix the tune, it should not be knocking especially if you were just tuned. The knock light is there to let you know that you should let off the throttle to avoid damage.
Old Mar 28, 2013 | 09:49 AM
team714's Avatar
its gonna be like a month before i go back to socal. it flashes slow.
Old Mar 28, 2013 | 11:01 AM
llDemonll's Avatar
you should not go back to the same place if your tuner told you that the engine knocking is fine
Old Mar 28, 2013 | 11:11 AM
gsrboi80's Avatar
You would need to open your rom to see what the Slow Flash on Knock Threshold is set to.
Old Mar 28, 2013 | 11:13 AM
Jim3142's Avatar
I would try another tuner (either in the Bay Area or an online tuner) since you're getting knock when going highway speeds in 6th gear.
Old Mar 28, 2013 | 01:20 PM
egis's Avatar
if its flashes like turn signal speed no biggy,if faster it's knock.
Old Mar 28, 2013 | 02:33 PM
evo8426's Avatar
Fast and slow flash are both knock
Old Mar 28, 2013 | 06:26 PM
egis's Avatar
Yeah but faster flash is where you should take it easy
Old Mar 28, 2013 | 07:08 PM
AndyCT9W's Avatar
Slow flash is still an indication of more knock than you want. The count required for slow flash would probably be set for 3-5/6 counts, more than I would consider OK.
Old Mar 28, 2013 | 07:18 PM
WikdEvo's Avatar
yep.. its knock. You don't happen to have any exhaust parts vibrating or anything do you?
Old Mar 29, 2013 | 09:01 AM
team714's Avatar
No i install a megan dp last week everything seem fine except when i used the megan dp spring bolts. rattled when i idle but now have the stock spring bolts on. rattle pretty much gone.
Old Mar 29, 2013 | 09:19 AM
superkizuna's Avatar
I wonder if it's just running lean and all timed up. I bet that's what happened. All that to give your the illusion of much more power after the tune.
