slight grind going into 2nd
Old Apr 3, 2013 | 04:37 PM
Czarcasm's Avatar
Recently I noticed whenever I go into 2nd gear there is a slight/mild grind. I inspected my trans fluid, it was full but I didnt like it so I changed it with AMSOIL 75w90. Drove it awhile, it got better but occasional grind here and there. Clutch is newish with no more than 2k miles on it. Will adjusting the clutch peddle make a difference? Adjusting the shifter cables?
I searched and found folks who had bigger issues than me, bad synchro/gear and such... any help is appreciated
Old Apr 3, 2013 | 04:41 PM
mossontree's Avatar
I have the exact same issue, but it doesn't really bother me. I think it's just your synchros getting a bit old. That being said, I have 98k miles. I don't think it's a problem, but I don't know how bad it is for you personally. Mines somewhat random and happens once or twice a day. Also my clutch also has about 2-3k miles on it.
Old Apr 3, 2013 | 05:28 PM
Kevin Knight's Avatar
Does it happen at high rpm? If so it's prob your syncro
Old Apr 3, 2013 | 05:38 PM
Czarcasm's Avatar
I dont race the car because Im breaking it in til the tune, its normal driving and I never exceed 3k rpm.
Old Apr 3, 2013 | 05:41 PM
I had my 4th and 5th syncros go bad. They would grind at high Rpm shifting fast.
Old Apr 3, 2013 | 05:45 PM
Czarcasm's Avatar
Thats what it sounds like for me, a good shep investment like you
Old Apr 3, 2013 | 05:56 PM
Terror Rising's Avatar
I have the same slight grind at low RPM, no issues up top. I adjusted the clutch properly, installed new shifter base bushings, shifter linkage bushings, and just got a Blox front engine mount to see if that gets rid of it (not installed yet). Next thing will be AMSOIL in the transmission. These make it so I don't feel it in my car:
1) Double clutch it with a throttle blip in between
2) Go from 1st to natural center, then slowly glide into 2nd. Don't force it and you'll feel when it wants to go.
I highly recommend making sure your clutch is adjusted properly. If it's dragging it will cause this. The shifter base/linkage bushings didn't eliminate it, but holy hell does it feel so much better. I'll let you know if the Blox helps out at all.
Old Apr 4, 2013 | 12:10 AM
MrJuls's Avatar
I'm getting a 4th gear notchy shift at high rpm.I'm going to install shifter base bushings and new clutch and see if that helps.Otherwise it's ordering a 4th gear synchro if i can or shipping the tranny to Jackstransmissions or Shep.Going to be costly as i live in SA...
Old Apr 4, 2013 | 06:24 AM
kanovic's Avatar
My 3rd used to do that, then it slowly started getting worse n worse and I ended up doing the 5speed swap. Chances are synchro is going bad.
Samo kupi 5speed Bolja transmisija lol
Old Apr 4, 2013 | 12:27 PM
Ricoswave's Avatar
Thats exactly how mine started, right before it started randomly popping out of gear. Every other gear is like butter, second gear synchro is toast. Previous owner may have banged that one in a few too many times.
Old Apr 4, 2013 | 05:16 PM
Czarcasm's Avatar
Thanks for the input everyone!
@kanovic. Trans dolazi za mesec dana haha. All the little pieces im getting right now, shift linkage etc. How long did it take you to swap it out
Old Apr 4, 2013 | 05:57 PM
kanovic's Avatar
Had a shop do it. Took then couple of days but I also put poly bushings in the rear diff and mustache bar. It's weird as hell going to the 5. Feels like a different car lol 6speed is so much more smoother but hey no grinds
Old Apr 14, 2013 | 12:19 PM
Werdna06's Avatar
I have the same problem with a slight grind at high rpm going into fifth.if it is a syncro problem then how much am I looking at spending to fix that?
Old Apr 14, 2013 | 04:54 PM
hiboost2.0's Avatar
Don't take this the wrong way but why are you at high rpm going into 5th? You must be going around ~115 haha. But it really depends whether you take the trans out yourself and send it somewhere or drop it off somewhere or get the entire trans completely rebuilt or just that single syncro replaced.
Old Apr 14, 2013 | 05:07 PM
xXANCHORMONXx's Avatar
happens every once in awhile at under 3500
