Passenger door key lock function question
Old Apr 5, 2013 | 05:07 AM
Lacoste's Avatar
Question Passenger door key lock function question
Can someone confirm how the passenger door key lock on an Evo 8 is supposed to function? I recently had body work on the door, and I could swear that the passenger lock functioned identically to the driver lock: turn the key forward or back twice and it would lock/unlock all doors. Mine's not doing that: is this normal, or did something not get reconnected properly?
Thanks,
Lacoste
Old Apr 5, 2013 | 05:44 AM
superbovine's Avatar
As far as I know none of them have a key cylinder switch on the passenger side or an actuator position switch on the passenger side. Wiring schematics confirm that, if they are accurate.
I only have two RS's near me to actually check though :P
Old Apr 5, 2013 | 07:00 AM
donzilla2004's Avatar
just tried mine, it doesn't do it.
Old Apr 5, 2013 | 03:51 PM
bonlamicq's Avatar
On my evo8 only work at drivers side, I never hear about on passenger side, I will check with others friends about...
Old Apr 7, 2013 | 04:45 AM
Lacoste's Avatar
Question Related: Driver door lock button gummed up
Thanks guys. I guess I imagined it
On a (somewhat) related note, the driver door lock doesn't open when I use the power lock function (internal power lock button, or remote). This actually prevents the remote from working if the drivers door is locked. It appears that the actual physical lock on the driver door (by inner handle) is kind of gummed up, but I suppose it could be a short as well. Anyone know of a solution to this? I can manually operate the lock, but it interferes with using the remote or even the power lock button on the passenger door. Should I just take the door apart and WD40 everything? Or is this a known issue that has a simpler solution?
Old Apr 17, 2013 | 06:27 PM
Lacoste's Avatar
Any recommendations about stuck driverside lock button on inside handle?
Old Apr 18, 2013 | 10:59 AM
matrho2792's Avatar
If you are going to spray anything in there to get it to move freely, I would either use triflow or dry silicone. As for it being a short, you could always pull the door panel off and see if it is binding up anywhere or just not functioning.
Old Apr 18, 2013 | 12:01 PM
barneyb's Avatar
I've never had a problem with my Evo but I've encountered situations on other cars where the grease applied at the factory, over time, got so stiff it even prevented the key from working. So, yeah, something with solvent like WD40 could be the fix.
Old Apr 7, 2022 | 03:09 PM
Vlu65's Avatar
Need help with the same issue.
ever fixed the problem? Recently paired a remote. Everything was fine and dandy then it suddenly started acting up.
Driver side only works manually, and the passenger/s would work only if the driver side is unlocked; using inside switch or keyfob .
NeoGearX
14
Jan 9, 2022 01:25 PM
UnholyMaggot
Jul 21, 2019 09:53 AM
daved912
Outlander Sport
May 23, 2017 11:21 AM
Jay10Ralliart
Outlander Sport
Feb 25, 2016 11:32 AM
07outty
26
Feb 6, 2016 07:18 AM
