Smoking after oil change
Hi All,
I just changed my oil, engine, transmission, and transfer case. After I finished, I test drove it and everything seems normal. Today, when I drove to work, I started smelling guess. I also started seeing smoke from my engine so I pulled over. I did not see any light go on. Can someone what's going on?
Thanks.
Thanks.
The tcase fluid is whats burning because its located right over the exhaust pipe and its in a tight spot so when refilling it take some effort to get the new fluid in and you will end up spilling and that what happen to you,also you might not have sprayed degreaser and rinse off the area so once you went home and park the car the residue dripped and settled on your exhaust pipe causing it to smoke.You should be fine just rinse off the spill oil next time.very thick and
SikEvo8
Oct 26, 2008 08:31 AM
omniprobe
Feb 25, 2008 09:44 PM
