Keep the injectors?
Old Apr 15, 2013 | 11:34 AM
EvoIXPilot's Avatar
Keep the injectors?
Mods are in signature. I installed FIC 1050 with the plan of goine E85 but now changed my mind. I'm not planning to mod the engine or anything else, just want to use what I have decent power. Would I still benefit from the injectors or should I go back to stock ones?
Old Apr 15, 2013 | 12:06 PM
heel2toe's Avatar
If you're sticking to normal pump gas, then you have no need for the larger injectors. Sell them, pocket the money and call it a day.
Old Apr 16, 2013 | 02:12 AM
MR. EVO MR's Avatar
Remove and rescale the injectors won't be worth it.
Those that you have are fine.
SilverLanEvo's Avatar
1050cc are small injectors for e85 anyways, correct me if im wrong. You'll be fine with the 1050s
Old Apr 16, 2013 | 06:08 AM
heel2toe's Avatar
Folks you are reading the question wrong. His plan was to switch to e85 hence the larger injectors. Now he decided to stick with regular pump gas so the question is, will he benefit from the larger injectors? The simple answer is no he will not. The stock injectors will not be maxed out thus its a waste of ~$300 as they will be doing him absolutely no good. That $300 bucks will be much better back in his pocket to help pay for gas, oil changes, coffee, sandwiches, beer etc etc
Old Apr 16, 2013 | 07:50 AM
evodriver49's Avatar
if its not self tuned, than you'll waste more money having to rescale and do another 91 fuel map/ tune. Keep them if this is the case.
Pruetmic1
Lancer Engine Tech
Oct 11, 2016 05:55 PM
Hotflarexxx
12
Oct 16, 2014 08:24 AM
tim85851
16
Apr 6, 2010 11:25 PM
Nex1
Feb 17, 2010 08:49 PM
Jp7
May 20, 2009 07:49 AM
