stock evo 9 wastegate actuator
Old Feb 20, 2014 | 10:19 AM
cmspaz's Avatar
Originally Posted by EVOIX-BIZERTA
I LIVE IN A COUNTRY WHERE AM ONE OF THE 2 EVO 9 OWNERS. THE MITSUBISHI DEALERS THERE ASKED ME NOT BRING IT TO THEIR SHOPS FOR REPAIR SINCE ITS NOT A MODEL THAT THEY SELL IN THE COUNRY. BOTTOM LINE, I PURCHASED THE CAR WITH A BLOWN TURBO AND FIGURED THAT OUT AFTER ME AND MY MECHANIC SPENT WEEKS WORKING ON IT, IN THE MEAN TIME I BOUGHT A STOCK BOV, A NEW WASTEGATE SELENOID, A NEW EGR VALVE, A NEW EGR SELENOID, THE TWO O2 SENSORS, ETC.. AND FINALLY I PURCHASED A NEW STOCK TURBO. AFTER INSTALLING THE TURBO THE CAR WORKED FINE AND BOOSTED AND IT WAS FUN THEN 4 DAYS LATER I STARTED HEARING A LITTLE WHINING FROM THE ENGINE THAT BECAME OBVIOUS LATER AND MOST OF THE BOOST WAS GONE. I RUN A LEAK TEST AND I FOUND A LEAK FROM THE Y ( y SHAPED HOSE) HOSE, ONE OF THE WG SELENOID HOSES AND THE THROTTLE BODY SEALS. I FIXED ALL THE LEAKS AND REPLACED THE TB SHAFT SEALS AND NOW THE CAR IS BOOSTING BETTER BUT NOT LIKE IT USED TO WHEN I FIRST INSTALLED THE TURBO. I STILL HEAR THE WHINE ESPECIALLY WHEN I CHANGE GEARS AT HIGH RPM ( METAL STOCK BOV) PLUS WHEN THE CAR IS ON NEUTRAL N I GIVE IT GAS FROM THE TB THE ACTUATOR DOESNT MOVE AT ALL . WHEN I FIRST INSTALLED THE TURBO THE ACTUATOR USED TO MOVE !!!!
COULD IT BE MY WG SELENOID WENT BAD?? MY ACTUATOR CAME WITH THE TURBO NOT EVEN 500 MILES IN THEM!!! PLEASE HELP
Holy ****ing caps lock, Batman.
Okay dude, first off, the OE actuator has a 12psi spring. You won't build 12psi free revving or off a two-step, so the actuator shouldn't be moving under those conditions. Why it was when it was brand new and isn't now, I have no idea.
Second, the WGA will not cause any sort of whining noise. You've likely got a boost leak still or something else wrong.
Third, if you're replacing things like EGR and O2 sensors for a low boost situation, it's time for a new mechanic, someone who knows about turbocharged cars, and not whatever joker you've got wasting your money now.
Old Feb 21, 2014 | 04:21 AM
EVOIX-BIZERTA's Avatar
Thanks i think it is a boost leak because i CAN hear thé whistling now when im pass 3000 RPM especially when i let off gas n keep my foot on thé clutch at high rpm. I already fixed 3 leak i Will Check tomorrow for vacuum leaks with thé carburator cleaner. Will let u know what happens
EVO8LTW
30
Oct 29, 2018 03:17 AM
def1
Feb 2, 2017 10:34 AM
blknblubkrdude
40
Apr 22, 2014 09:23 AM
Mrauto50
Jul 30, 2012 08:42 PM
shotgun_joshy
18
Oct 31, 2011 05:43 PM
