Car vibration at 45pmh
Old May 1, 2013 | 08:07 AM
barneyb's Avatar
Originally Posted by fillis
Okay so update, I tried to get it to misfire/lose power/dash lights come on whatever it has done a couple times since I owned it. Couldn't get it to do it. The vibrations do not exist in 3rd and is very feint in 4th, I tested 3,4, and 5 all at the same speed.
Barneyb - Did you Evo have this drivetrain issue, did you have it fixed? what fixed if you did and how long did you drive it that way before having it fixed?
Or is it not a big deal like BEKevo might be proposing?
Once again thanks everyone for the input!
I'm the sole owner and the odometer is between 85K and 90K (too lazy to go look). I first encountered the p0300 code when the car was less than a year old and first noticed the body vibrating at around 60 mph after the first tire change - probably around 15K. The tires I put on were not very good or very expensive.
Other than blocking the p0300 code in the ECU I've done nothing to the drive train. I'm still on the stock clutch. Currently I'm on Star Spec tires and they eliminate the body vibration completely. So, I have no personal experience as to what the transmission will need after driving with the car shaking for a lot of miles. Others have written that I should expect to replace fifth gear and a main shaft.
ralliart425
21
Apr 9, 2017 08:57 AM
adolfo415
Jun 29, 2013 01:21 PM
PaulyX
Jun 26, 2013 01:54 PM
Don Q
Sep 16, 2011 08:21 AM
4g63Moon
Jul 22, 2010 03:06 PM
