Weird start up issue
Old May 17, 2013 | 06:00 PM
raven1231's Avatar
Ok thanks I'll check that asap, there was a tee in the line and it looks like it snapped in half causing the problem.
Old May 17, 2013 | 07:02 PM
raven1231's Avatar
I checked the lines they seem to be connected toward the back of the engine under the intake manifold. I have no idea where the other end is suppose to run to or is it just suppose to be teed?
Old May 18, 2013 | 01:54 PM
raven1231's Avatar
so based on the location and color of the two lines, yellow and green/blue. I think they go to the EGR solenoid. I can't however locate the solenoid. I'm starting to think it might have been removed. Can you access it without pulling the intake manifold. Also if it is removed do I just need to tee the line? It looks like thats what was does before as there was a broken black tee between the two.
Old May 18, 2013 | 02:57 PM
4RETECH's Avatar
The egr solenoid is bolted to the metal bracket supporting the intake manifold.
Maybe it broke the plastic, find it, unless you deleted EGR I would Try and fix it.
Old May 18, 2013 | 03:49 PM
raven1231's Avatar
Well I think that about answers it. I went and looked at the EGR solenoid and didn't feel either nipple where it was suppose to be. I guess the plastic wasn't a tee but the nipples broken off in both lines. Anyone know where I can get the part other than a dealer?
Old May 18, 2013 | 05:35 PM
MileHighX's Avatar
There are a few sponsors on here that sell OEM parts, MAP, STM, and I'm sure many others. Good luck hope it solves your issues.
Old May 24, 2013 | 03:13 PM
raven1231's Avatar
Well the EGR solenoid is fixed and vacuums lines are hooked back up. However I still have the same problem...
Old May 24, 2013 | 09:50 PM
S3CR3T's Avatar
This is a long shot but my car did this once and I had a tuner look at it and supposedly my car was running too rich and it was causing my aem wideband to go haywire and causing my car to shut itself off from getting fuel. It didnt really make sense to me how my wideband would get confused thats just how he described it and I am no tuner so I couldnt argue all I know is I got a retune and my problem disappeared.
But literally the same symptoms randomly would die at idle and giving it gas sometimes would help. (im assuming youre talking about that split second it turns over before dying again when giving it gas)
Old May 24, 2013 | 11:32 PM
matrho2792's Avatar
If you do end up needing anything from the EGR system, I deleted mine so I have all the EGR components laying around.
Old May 25, 2013 | 07:12 AM
raven1231's Avatar
I posted a video of it on the first page, showing what it's doing. This all just happened out of no where one night. But yeah basically it will start then sputter and die. Now if as soon as I turn it over I rev the engine up it well level out and idle.
Old May 30, 2013 | 08:26 PM
raven1231's Avatar
So after taking it to car x and the guy telling me he has no idea what it is, i did some more looking myself. I think the problem is the IAC. I pulled it out and it was black. I tried to turn the car on with it plugged into the connector and it clicked but didn't move. Does this mean its bad?
Old Jun 6, 2013 | 07:26 PM
raven1231's Avatar
Replaced IAC and still have the exact same issue....any ideas? Im willing to pay someone if they can help me figure it out.
Old Jul 25, 2013 | 08:11 PM
sublime44's Avatar
Did you ever figure out what was causing your issue? I have a similar one, but my car won't even start anymore.
Old Jul 25, 2013 | 08:41 PM
impact blue's Avatar
Check those vacuum lines they go both to the top of the throttle body on top of the intake manifold. Do a boost leak test and change out the maf sensor.
Old Jul 25, 2013 | 08:59 PM
CDHoff's Avatar
Just stumbled on this thread and I'm having the same issue. I would go to start the car and it would start but struggle then turn off. Then I'd try it again and give it some gas and it would start and smooth out during idle. One time though it cut out on me when I was making a slow turn and I barely got it going again. It drove fine after that though for a few days. Now the car won't start at all! I thought it was the heat n humidity but now I'm at loss.
