loose power boost
Old May 1, 2013 | 03:21 PM
kastilo's Avatar
loose power boost
Hello to everybody,
I'm italian and I write you from Italy...first of all I'm sorry if my english will be not so good...I'll try to do my best.
I have a lancer evolution 9 gsr with big bore tb and complete exhaust system from elbow to back.
Now I find a problem with the boost...
When I put 100% throttle the pressure goes to 1.7 of peak and after jump immidiatly to 1.0 bar to rpm
end...
I change wastegate actuator with a new one...change also the actuator solenoid valve and check every hoses...also check bov and everything is working fine.
When pressure start to loose I heard a sound like a vavle that open and pressure goes out from there...
Can you help me to solve this problem?
Many thanks
Old May 2, 2013 | 06:17 AM
crazybaldhead's Avatar
Boost leak, bad. Check your lower intercooler pipe coupler.
Old May 2, 2013 | 01:16 PM
Walter1986's Avatar
Also do a boost leak test.
def1
Feb 2, 2017 10:34 AM
KingTal0n
Nov 27, 2016 05:23 PM
crcain
15
Dec 10, 2015 06:19 PM
joynt2002
Apr 21, 2015 10:12 AM
azzaevoviii
Dec 9, 2013 07:26 PM
