engine mount questions:
Old May 7, 2013 | 04:55 PM
kaj's Avatar
kaj
i recently began to have some vibration between 2500-2800RPM. it began suddenly and out of nowhere. everything else is fine, so my first thought was an engine mount. the car has about 118k on it.
i took a look at the mounts and they "look" fine. did i read correctly that they should have no movement while revving the engine, etc? i can rev the car from the TB and see some movement in the passenger mount bushing. does this mean it's bad? i didn't bother to look at the others until i know if i'm wasting my time LOL. i see no obvious damage to any of the mount inserts.
thanks in advance, guys.
Old May 7, 2013 | 05:04 PM
Thore's Avatar
Stock motor mounts are rubber and you would notice some movement when reving. Now if it's acting like it wants to jump out of the engine bay, then you might want to look into some mounts. You could always just get some stiff motor mounts, then you would know why it's vibrating lol.
Check the downpipe and see if you notice any rubbing marks. Depending on the DP you have, there might be some clearance issues.
Old May 8, 2013 | 08:06 AM
satan's rx7's Avatar
Get a big prybar on the suspect engine mount and apply pressure. Find a friend or homeless guy to rev the engine to the trouble RPM area and see if the vibration changes while pressure is applied. This should help rule out the motor mount as the culprit.
Is the vibration evident when parked AND driving? Only when driving? Only when parked?
vortico
Apr 19, 2017 09:49 PM
TommiM
15
Sep 30, 2014 04:46 PM
Evowith750awhp
Oct 16, 2013 11:41 AM
project_skyline
18
May 11, 2012 09:18 AM
newimportowner
Dec 12, 2011 12:54 PM
