Sporadic oil pressure.
Old May 8, 2013 | 11:28 PM
VR4-EVO's Avatar
Okay, so I was driving home tonight and couldn't help but notice my oil pressure jumping around under high boost. It would typically hover at 80 then drop to 60 and bounce around all in between there. Is this normal?
Old May 9, 2013 | 01:12 PM
ReidFletcher's Avatar
Oil level is full?
What sort of gauge are you using to measure pressure?
Old May 9, 2013 | 01:23 PM
ProPilot04's Avatar
No it isn't normal. I'd suspect your gauge is busted, the connection for your gauge is faulty, or you have an oil blockage somewhere.
What does your oil level look like?
Old May 10, 2013 | 11:58 AM
VR4-EVO's Avatar
Well I just changed the oil and sea foamed her and it seemed to have fixed the problem whatever it was. Probably should've tried that before posting... Thanks anyways guys!
Old May 10, 2013 | 01:00 PM
ProPilot04's Avatar
Changing your oil, and seafoaming your engine probably didn't fix the problem, it fixed the symptoms.
I would advise you to keep an eye on things, and regularly check your oil level.
Old May 11, 2013 | 08:29 AM
VR4-EVO's Avatar
I'll take heed to that advice. I'll come back with an update in a couple of days.
e_kobz
Mar 24, 2014 10:43 PM
fjm9898
11
Feb 7, 2013 02:28 PM
m34g63
15
Oct 19, 2012 02:31 PM
Frew
12
Oct 12, 2012 05:59 PM
chasesyellowevo
29
Sep 17, 2012 03:29 PM
