no boost in 1st
Old May 12, 2013 | 09:51 AM
Deanjobs666's Avatar
no boost in 1st
So recently I've noticed i'm getting very little boost in first, a little more in 2nd and by 5th and 6th i'm getting pretty much normal boost. Anyone know what might be going on? I got the car about 5,000 miles ago and haven't been beating on it.
Old May 12, 2013 | 11:08 PM
sadc's Avatar
Any mods? Boost controller solenoid maybe
Old May 13, 2013 | 12:31 AM
car is pretty much stock only has an exhaust and intake. tonight I was getting about 14 psi in 1st as opposed to the 7 i was getting earlier today so i really have no clue whats going on.
Old May 13, 2013 | 01:54 AM
blr2g's Avatar
It may be your wastegate actuator needs to be adjusted 3-4 turns to give it more preload. If there is not enough preload the wastegate flapper opens too early and causes lag and fluctuations.
Of course, you should definently run a boost leak test to see if a hose has popped off or something.
Old May 13, 2013 | 09:23 AM
superkizuna's Avatar
Stock BCS? I bet your car is tuned for boost by rpm. You can do that in stock ECU.
Runker
Aug 31, 2013 11:57 AM
Daddymac
19
Apr 12, 2012 08:24 AM
Ichimaru
Jun 24, 2010 02:48 AM
accident
Jul 5, 2007 10:39 AM
AlwaysinBoost
12
Nov 26, 2006 04:28 PM
