Is this too much OIL? with PICS
Old May 17, 2013 | 09:56 AM
gabegonzales's Avatar
Im an idiot, didnt seal the oil filter on right so i did an oil change and most of the oil drained out.
so i fastened it right and put more in
the other day i checked it and it seemed to be low on the dipstick so i added 3/4th a quart more
and now its past the full line
leave it as is, or drain some out from the drain plug ?
Old May 17, 2013 | 10:00 AM
misterevo8's Avatar
ummm... pics?
Old May 17, 2013 | 10:05 AM
misterevo8's Avatar
nvm, its fine. not worth the trouble to drain some. unless you are really afraid then go ahead and drain a little. dont take the plug all the way out. just crack it till it drips and the keep check i guess.
Old May 17, 2013 | 10:07 AM
b16a2delsol's Avatar
Its not hard to drain the extra off, but no it will not hurt your car. I have had my level where yours is a few times with no Ill effects.
Old May 17, 2013 | 10:37 AM
deylag's Avatar
Yep this oil level is fine.
Old May 17, 2013 | 10:43 AM
gsrboi80's Avatar
No worries man you're fine there
Old May 17, 2013 | 11:18 AM
Grant's Avatar
Don't drain any - I have it on good authority that running above the top mark (up to an extra quart) on the dipstick is desirable on these cars...
Old May 17, 2013 | 11:37 AM
bitterchild's Avatar
Do share the good authority you reference so that we may place the appropriate amount of confidence in your epinion.
Old May 17, 2013 | 11:41 AM
Bruzewski's Avatar
I run mine just a bit lower then that all the time.
Old May 17, 2013 | 11:47 AM
Raptord's Avatar
Old May 17, 2013 | 11:54 AM
5LEEPERISAH23I's Avatar
that is fine, turbo car tend to burn oil naturally. In 1.5k-2k miles it will prob be at the full mark.
Old May 17, 2013 | 02:52 PM
Grant's Avatar
Jack's Transmission
Old May 18, 2013 | 10:40 AM
Teal2nnr's Avatar
Fine, I usually put in extra oil if i'm doing a track day (circuit) about the amount you have on your dip stick.
ak47po
33
Mar 21, 2016 11:31 AM
mrm95
14
Aug 4, 2013 09:57 PM
IX_MR
Dec 8, 2012 10:57 PM
MISHI
20
Aug 23, 2009 08:18 AM
03whitegsr
10
Jun 2, 2009 10:41 AM
