AVC-R issues with video
For the love of me I cant figure this thing out. I have it set to 1.45KG. My duty cycle is around 60-68%
F/B and Learn gear are off for the time being while I setup my boost.
So It does hit the target boost but while its at 1.45kg it sputters. No matter what I do, it sputters over anything that goes over 1.00kg. I did setup the ETC to this...
Heres the vid. Its kinda hard to hear but it is sputtering when It hits the target boost. Again no matter if I fool around with the duty cycle or start duty.
Car Select- Cylinder, Vehicle Speed Pulse, Throttle Type setting
Set these to 4 4 arrow up don’t ask why just do it It is the same for an evo or a scoop the same.
Sensor Sel - Pressure Sensor Type setting
Use 1
Gear Judge - Gear Judge setting
In order for the AVCR to determine gearing, the Gear Judge feature must be set.
Choose the gear you want to set, on the right side you'll see the ratio (RPM/Speed) which the AVCR uses to determine which gear its in.
- Choose which gear you want to see using the Up/Down keys. Press the Next key to choose that gear
- Drive the car in that gear at a moderate speed 3000revs is more than enough for each gear. Press Next to set that gear
- Press the Left key to return to gear selection and repeat for the other gears in your car speed.
Grph Scale - Graph Scale setting
Bs: Boost range.
Ne: Maximum RPM of your car
Sp: Maximum speed of your car
Sensor chk - Input Signal check display
VFD Bright - Display Brightness
Initialise - Initialise all data to default, don’t press this one unless you really want to wipe everything you have ever done. !!!!!!!!!!
Use 1
Bs: Boost range.
ChicagoEvo9
Sep 15, 2014 05:31 PM
audiofan
May 16, 2014 10:53 AM
EvoDan2004
28
Oct 25, 2013 07:58 PM
