Is a slight 2nd Gear Grind common on the 8/9
Old May 25, 2013 | 07:37 PM
GSX 911's Avatar
So Is a slight 2nd Gear Grind common on the 8/9? Maybe not a full grind but a slight "different " feeling when going into 2nd gear.
Old May 25, 2013 | 08:48 PM
intoaevo's Avatar
yeah i get it on my evo 8 i get 2nd and 3rd sometimes. even when i rebuild the tranny it was doing the same thing.
Old May 25, 2013 | 09:20 PM
BEKevo's Avatar
Is your clutch adjusted correctly ? And what kind of fluid are you guys running ?
Old May 25, 2013 | 09:24 PM
BEKevo's Avatar
And our transmissions' are known to be "notchy", but not for grinding in any particular gear, unless you exceed the torque threshold of the transmission (ie depends if you have a 5 speed or 6, as they're different)
Old May 25, 2013 | 09:34 PM
EvolutionIX219's Avatar
Mine sometimes grinds when going into 2nd
Old May 25, 2013 | 09:47 PM
BEKevo's Avatar
Answer my questions posted above and I can help you out a little better. Also list your power output and type of clutch.
And for the others that have posted here's a link to adjusting the clutch "properly"
Jackstransmission's
Scroll down a bit to view the video.
Old May 26, 2013 | 02:52 PM
awdordie's Avatar
From what i have read nd heard 5th is the notorious gear for grinding when trying to slam it into gear. The synccros in our trans are crap. If u slowly go into 5th mine wont grind only when i shift a little too fast.
Old May 26, 2013 | 05:38 PM
Mine only grinds when going into 2nd at low rpms. I aways figured it was my car calling me a vag. It doesn't bug me too much yet. I got my TC rebuilt and that took two months. Don't feel like going through that process again at the moment.
Old May 26, 2013 | 05:48 PM
cwyteboi's Avatar
Mine always wants to grind going into 3rd unless I put a little 'Wrist English' into it. Adjustments are within specs, fluid is stock and swapped per service intervals. I'm thinking the synchros are a either a bit worn or just funky. Has been like that since I brought her home with 7k on the ticker, 44k now, no change. Won't worry about it till something actually breaks.
Old May 26, 2013 | 05:55 PM
01397's Avatar
my 2nd does that when its cold, once the cars warmed up its sweet
Old May 27, 2013 | 12:23 AM
importmachine's Avatar
It happens to my MR. When it's cold or shifting at low rpm's it makes that sound. I've just learned to live with it and it doesn't bother me anymore.
Old May 27, 2013 | 03:27 PM
Skyline1215's Avatar
Common on MR's
Old May 27, 2013 | 03:44 PM
Jimmy Javelin's Avatar
I dont grind in 2nd in my MR.....
380/360.
A little random but, BEKevo, I'm diggin that rally headlight setup!
Old May 27, 2013 | 05:05 PM
BEKevo's Avatar
Haha thanks PsychoAmbrosia
Old May 27, 2013 | 05:50 PM
DeeezNuuuts83's Avatar
I've had two Evo IXs with five-speeds, both of which were purchased new but grinded in either second or third (I can't remember which one) for the first few thousand miles. Like someone else said, fifth grinds once in a while if you're really accelerating hard and shift into fifth quickly, but it's nothing to get too worried about. It rarely ever happens now.
