Is a slight 2nd Gear Grind common on the 8/9
Old May 28, 2013 | 12:48 AM
Jorda420's Avatar
I had a similar problem with grinding into 2nd. I ended up changing the under hood bushings to the solid buschur ones. And I also changed the in cab shiftier bushings. They were energy suspensions I think. But it worked.
Old May 28, 2013 | 09:33 PM
dayak's Avatar
grinding gear on any gears in cars, evo especially is not normal at all
Old May 29, 2013 | 05:27 AM
GTijoejoe's Avatar
"normal" or "common"?
Its common, the 2nd gear grind happens a lot, mostly (in my opinion) due to the shift linkage.
I've noticed in my car, if I shift to second and put a small amount of LH side force on the shifter as you go into second it shifts butter smooooooooth every time, if not, you get that slight notchy grind.
Old May 29, 2013 | 09:31 AM
Thore's Avatar
My 2nd gear was notchy as hell and I would have to take extra care to no grind into 2nd. This was more apparent in the cold mornings. I've since added a braided clutch line, new fluid and had the petal adjusted. Shifting from 1st to 2nd is much easier now.
5th gear is still giving me trouble
Old May 30, 2013 | 09:14 AM
BEKevo's Avatar
For those of you with worn transmission synchros (ie causing your notchy shifting). I recommend rebuilding your transmission through Jackstransmissions. As they "blueprint" their synchros during reassembly of the transmission. This improves shift quality and efficiency dramatically. Well atleast it did for me...
Here's the link to the process.
Jackstransmissions "Synchronizer Blueprinting"
http://www.jackstransmissions.com/pa...o-blueprinting
Old May 30, 2013 | 09:50 AM
rongdoer's Avatar
This has been discussed before. The soft stock engine and tranny mounts flex under torque. While flexed something in the shift linkage becomes out of alignment. Stiffer motor mounts and it's gone, athough you'll have slightly more vibration in the cabin.
Old May 31, 2013 | 08:15 PM
BEKevo's Avatar
That does not account for the low speed, "notchy" second and third shifts (where the motor is barely under load). Under hood and shifter bushings help that dramatically, and so does the correct transmission fluid.
The rollstopper is what prevents the motor from rotating backwards, which I think is what you mean by motor mounts.. The stock motor mounts have been proven up to 600+ hp.. Upgrading the rollstopper improves the shift quality at higher rpms, where more load is exerted.
Dolly
Mar 28, 2016 11:37 PM
9!'clipseDOHC
Jul 7, 2015 05:25 PM
ArchieBabes
17
Feb 16, 2013 06:11 PM
YoManStation
23
Dec 10, 2012 06:52 PM
raytrix
13
Jun 8, 2010 08:11 AM
