Mystery bolt
Old May 26, 2013 | 04:31 PM
WikdEvo's Avatar
Question Mystery bolt
Just removed my turbo and manifold to install some new goodies and I came across this bolt. It doesn't look like it serves any real purpose. Any one know what it's there for?
Old May 26, 2013 | 04:44 PM
evoxsi's Avatar
it to insert a tool to lock the oil pump from moving when doing timing belt changes
Old May 26, 2013 | 04:49 PM
WikdEvo's Avatar
Thank you very much sir
Old May 26, 2013 | 10:48 PM
Grimgrak's Avatar
Any idea what this tool looks like? Never recalled using it when I did my timing belt.. then again I do have a oil leak now in the timing belt cover :O
Old May 26, 2013 | 11:47 PM
Czarcasm's Avatar
Like stated above, tool for a oil pump. Insert a screwdriver or something similar
Old May 27, 2013 | 05:34 AM
evoxsi's Avatar
if you didnt use they tool then theres a chance your oil pump
is 180 degrees off
Old May 27, 2013 | 07:44 AM
WikdEvo's Avatar
So that hole actually goes all the way into the block
Old May 27, 2013 | 01:45 PM
barneyb's Avatar
By way of the timing mark it is possible to align the balance shaft, driven by the oil pump, in two positions only one of which is correct. If you operate the engine with the balance shaft in the wrong position you will encounter a harsh vibration at 4K rpms.
Removal of the bolt allows you, by way of a screwdriver, to tell the position of the balance shaft. I avoid this step by not moving any of the sprockets as the timing belt comes off.
So, yeah, the hole goes through the block.
Old May 27, 2013 | 01:51 PM
superbovine's Avatar
You don't even have to be that careful..... align the mark on the oil pump gear then twist the gear 90 degrees and let go. If the mark springs back up toward the aligned position you are in phase. If the mark falls down to the bottom your are 360 degrees out of phase and have to spin the gear around once.
**** that bolt lol.
Old May 29, 2013 | 09:23 PM
Grimgrak's Avatar
So if i dont have balance shafts do I still need to use this bolt to align the pump?
Old May 29, 2013 | 11:54 PM
matrho2792's Avatar
Nope. Like everyone else has already stated, it's to insert a screwdriver to keep the shaft from spinning.
evilempire76
Oct 22, 2013 12:41 AM
Randal
Sep 26, 2013 04:50 PM
Pirana
Apr 19, 2013 05:01 PM
notenoughhp
Mar 16, 2013 11:58 PM
ZWingerRyRy
Dec 11, 2012 10:52 AM
