Making your Evo heavier
Old May 28, 2013 | 06:23 AM
Jimmy Javelin's Avatar
Most people try to reduce weight in their Evo.
Has anyone ever added ballast/weight to certain sections of the car to handle differently?
Im getting rid of some bilsteins and had them packaged in my trunk, long story short, my car has never handled so well around town, power distribution felt very neutral, and cornering was sharper and crisper.
And traveling at 140mph felt great, very stable.
Most of us agree that getting up to speed from a dig w a 2.0L is a PITA without boost, it was so easy and fun.
Btw I had 70lbs of weight in rear.
Thinking about taking out rear seats and backing and seeing if it still feels just as good
Old May 28, 2013 | 08:41 AM
Czarcasm's Avatar
What did you replace the Bilsteins with?
Old May 28, 2013 | 09:37 AM
MechTech's Avatar
^This..... Either you upgraded your suspension or the suspension you took off was toast lol. In theory it could settle the rear suspension more resulting in less lift in the rear at speed or hard cornering. Are you running a wing?
Old May 28, 2013 | 10:40 AM
KW V3's.
I've been driving with the KW's for about a month.
There was a HUGE difference when I added "junk in the trunk" if you will.
I honestly think it was possibly extra weight pushing on the rear tires giving it more grip.
And I'm wingless. But it never had this feeling when I had the wing on....
Feels good..I kinda like it.
Old May 28, 2013 | 11:03 AM
Czarcasm's Avatar
I wouldnt say it has anything to do with weight, its the suspension setup, imo
Old May 28, 2013 | 11:04 AM
deylag's Avatar
The Evo has a uneven weight distribution. Adding more weight to the rear does help increase handling but you could accomplish the same effect by corner balancing the Evo.
It would stand to reason that even though it "feels" more planted its slower. Adding more weight always slows you down.
Old May 28, 2013 | 04:16 PM
MechTech's Avatar
This is possible too. Check how still you have your suspension set too. I'f its real stiff and you added weight it could give you that feeling, maybe turn it down a few clicks and see if that gives you the same result.
Old May 29, 2013 | 02:52 PM
barneyb's Avatar
I noticed this too. I once used my Evo as a moving van - had the back seat out and the trunk filled and the back seat to the roof. I didn't do anything crazy with this load on but I expected the handling to degrade like it would in any other car. Just before this I brought my mother's car (a Honda) from California to Colorado also loaded as a moving van. With it I had to take curves 10 mph below the speed limit. So, I was surprised when the Evo drove like it was empty. This on stock suspension.
Maybe, in rally racing the co-driver should sit in the back seat.
Old May 30, 2013 | 04:02 AM
siikEvo92's Avatar
You could use the nasty sticky, heavy dynamat in certain areas? It weighs a good bit
Old May 30, 2013 | 04:18 AM
fightex's Avatar
Adding weight in the trunk effectively decreases the rear spring rate, making the ride better. As others have said, making it closer to 50/50 F/R balance (which the Evo will never be) will create a better handling balance.
EVOlutionary
May 13, 2019 09:34 PM
supersnow
Mar 14, 2014 02:35 PM
David Buschur
228
Feb 10, 2013 11:06 PM
tack
Aug 26, 2010 08:36 AM
crypto
15
Mar 18, 2009 01:03 PM
