Clutch Pedal
Old May 27, 2013 | 07:34 PM
bryonboals's Avatar
Clutch Pedal
My clutch pedal get stuck a lot. I have to use my foot to pry it up, so I can shift. Just wondering if anyone else had the same problem and how they fix it
Old May 27, 2013 | 07:38 PM
4RETECH's Avatar
I would try and bleed the slave cylinder first. Then check to see if it is binding.
I've only seen one slave cylinder fail and that was on a car that sat a lot.
Old May 27, 2013 | 08:08 PM
bryonboals's Avatar
how do you bleed the slave cylinder
Old May 27, 2013 | 08:26 PM
bryonboals's Avatar
Found a great how to on evomoto.com
Thanks
Old May 28, 2013 | 10:34 AM
Dbz00's Avatar
check ur fluid
Old May 28, 2013 | 10:55 AM
chu's Avatar
chu
Also check for leaks. I've encoutered a punctured stainless line, and the cracked stock line all in one week. lol.
Old Jun 6, 2013 | 12:39 PM
spiXel's Avatar
i had this problem, changed the fluid and it was all better
Old Jun 6, 2013 | 01:18 PM
NJ_evoIXgsr's Avatar
Veteran: Navy
I went through this problem very recent. search: dead, sticking clutch pedal
Do not go directly to the clutch if there isn't tall tale signs of the clutch was the originating problem. As others have mentioned, check for leaks. Smell the fluid or if it is green then it is likely leaking brake fluid. Remember clutch and brake share the same reservoir.
My issue ended up being the clutch line. Two lines, upper and lower. At the center of those lines mine failed because it was overtightened and thus a crackturned into a nice leak.
If there is no leak, then try bleeding the line. As you mentioned, evomoto.com has the best tutorial how to bleed the line. Almost the same sh*t as bleeding your brakes but will need a helping hand!
If you notice it helps and comes back, check again for that leak. The hardline can have hairline cracks that are hard to see and cause it.
Best solution IMO, would be the 1piece clutch line. I forget by who but just do a quick search and it'll come up as it's the only one on the market which is also available through the forums vendors!
DuBBzEvo27
Jun 16, 2014 09:58 PM
Uscbryan
Jun 7, 2014 08:46 PM
Iowa999
Apr 30, 2012 12:25 PM
domantas
Jul 4, 2010 11:42 PM
ambystom01
Lancer Tranny/Drivetrain Tech
11
Apr 21, 2010 03:34 PM
