Lancer Tranny/Drivetrain Tech Anything drivetrain related can be discussed here.
Clutch Pedal Adjustment?
Old Jun 9, 2005 | 08:42 PM
ambystom01's Avatar
Is it possible to adjust where in the pedal travel our clutch engages? My clutch still grabs perfectly fine, its just doing so a little higher in the pedal travel than I'd prefer. Any help would be great.
Old Jun 10, 2005 | 12:15 PM
ambystom01's Avatar
bump.
Old Jun 20, 2005 | 08:26 PM
Supa tek's Avatar
I'm not positive but I think it automatically adjusts
Old Jun 20, 2005 | 08:44 PM
HobieKopek's Avatar
I don't think it can be adjusted. I could be wrong though.
Old Jun 21, 2005 | 12:01 AM
ambystom01's Avatar
Damn, I was hoping since the pedal can be adjusted on the evo maybe it can on ours. Well I'll find out soon since I'm going to the dealership in like 10 hours for some warranty work.
Old Jun 21, 2005 | 06:00 AM
wiretap's Avatar
I swear I've seen something about clutch adjustment.. I'll have to search for it.. I hate how far my clutch travels too. Its like pushing in a tractor pedal.
Old Jun 21, 2005 | 06:20 AM
wiretap's Avatar
Heres the one for the evo, you can check to see if it is similar to yours.
https://www.evolutionm.net/forums/sh...=clutch+adjust
Basically what it says is you have to get upside down on your back under the dashboard.. follow the clutch pedal up to where the clutch rod goes thru the firewall.. there is a 12mm nut on it that you have to loosen.. I guess you just have to adjust it until the clutch pedal is where you want it in conjunction to the floor. But if you go too far, it won't stay in gear, so you have to adjust it and test it how for how low you can go. Some people adjusted it too low and it pops out of 1st gear under acceleration. I'm going to check my car out after I get off work today to see if I can locate this 12mm nut on the clutch rod where it goes thru the firewall.
Old Jun 23, 2005 | 04:13 PM
oz4g94's Avatar
i would like to know also, i have just the exact opposite problem as everyone else. mine was engaging normal, then i got in my car the next day to drive and the clutch is engaging really low (probably about 1 to 2 inches from floor). ive never driven another manual car, nor had to replace a clutch, could this be a sign that i need to replace it?
Old Jun 23, 2005 | 04:30 PM
ambystom01's Avatar
Yeah when I took my car in for a warranty service they said it wasn't adjustable, but they say the same thing about the evo clutch so I don't know. When the clutch is going it engages really high up, not really low down.
Old Jun 24, 2005 | 09:12 AM
oz4g94's Avatar
i dont think it can, i read the thread that wiretap posted, they say to follow the clutch rod from the pedal to the top, and loosen or tighten a 12mm nut depending if you want your engaging point lower or higher, i believe that i found the nut they are talking about so i messed with it, and seems to have no relevance of the engaging point. so im not sure, i drove again today, and its getting to the point where i am scared to drive it because im afraid my car wont stay in gear. i need help quick.
Old Apr 21, 2010 | 02:46 PM
turbotboz's Avatar
Although bringing back from the dead, there is some misinformation in this thread. Thought I would share the proper method of adjusting a clutch for the most travel on dsm's/evo's/etc.
Big thanks to Jack.
http://www.youtube.com/watch?v=vYJxQ...layer_embedded
Travis
Old Apr 21, 2010 | 03:34 PM
ambystom01's Avatar
That's for bumping a thread asking for information on a car I no longer own.
Kris86
Oct 5, 2016 10:31 AM
Svendiesel
24
Jul 30, 2013 09:23 AM
cmross13
May 30, 2013 07:43 AM
Frew
May 20, 2012 04:44 PM
trinydex
Mar 29, 2007 05:40 PM
