Alt power wire
Old Jun 4, 2013 | 03:32 PM
Luke18's Avatar
Alt power wire
Hello everyone ...
My battery n brake lights can on when driving, after doing some research on EvoM it was determine that my alt was the problem. I raised the car disconnect the power and remove the other wires that attach with a clip. Looks like the power wire snapped off n broke. I wanted to know how hard is it to replace the harness and how far back does it go?
Old Jun 4, 2013 | 04:26 PM
ProPilot04's Avatar
Luke...
Can you post a pic? If you're replacing a wire, it could be as simple as pulling the sheathing back, and heatshrink splicing.
2 schools of thought here.
1. Solder it. Great connection, but prone to vibration damage.
2. Heat shrink crimp it. Ok connection, but less prone to long term vibration damage.
Old Jun 5, 2013 | 05:13 AM
Luke18's Avatar
Originally Posted by ProPilot04
Luke...
I posted pictures in the first post. I dont know if it can be soldered. But I would like to get something solid that will hold to vibration because it must of broken off when I was on the track.
Old Jun 5, 2013 | 11:14 AM
ProPilot04's Avatar
Oh it's THAT wire...
Huh. Well, it can definitely be repaired. If you can slide that black rubber cap back up the wire a bit, and pry the old ring (broken bit) off of there, figure out what size you need, and go get one of those heat shrinkable, weatherproof rings, and melt it right on. No need for solder, or splice and dice because it's the ring that snapped, not the wire.
If the wire looks charred, you may want to splice, but if it's just dirty... you can take some green scrubby pad to it to find out if it's damaged (arc'd) wiring, or if it's just dirt.
Bing boom done.
JohnBradley
Jul 10, 2015 02:00 PM
klutch814
Jun 5, 2014 04:35 PM
germanmike954
Apr 30, 2014 06:07 PM
Luke_S
Jan 19, 2014 07:25 PM
