Daniel's 820whp SLR2.2 6466TS monster
Old Sep 12, 2013 | 06:56 PM
JohnBradley's Avatar
Daniel has been around English Racing as long as English Racing has been around...or really really close. After the DSM days he stepped it up and started the path of Evolutions until he ended up back to an Evo 8.
It had gone through a few different incarnations on the stock 2.0L lastly on a BBK and E85. As happens in life the stars aligned and a sleeper street dominator was poised to happen. After seeing results from another SLR2.2 build that we did, Daniel decided it was the same combo he wanted.
With recent advancements in the AEM Series 2, it made more sense to switch to the AEM for the flex fuel capability and other needed features on a planned 800+whp build.
Foundation-
Evo 8
EnglishRacing SLR 2.2 (153mm/94mm)
EnglishRacing race port cylinder head
GSC S3 camshafts
GSC 5041 Valvespring set
Extreme Turbo Systems 6466 Twin scroll kit with 1.15 housing
Fuel Injector Clinic 2150cc injectors
Magnus V5 Intake manifold
SparkTech COP sequential ignition
Boomba 75mm throttle body
Squash Performance Dual 400lph fuel system
Sound Performance 3" test-pipe dump
Since this is primarily an E85 car and Flex fuel to boot, there wasnt much need for a killer pumpgas tune. That doesnt mean we didnt want it to be fun though and at only 19psi it should still make it pretty entertaining-
It came time to push the tune on E85 so after a bit on the dyno making sure the blending table was set where he wanted it, Luke put the screw to it-
We did our normal dyno video for the car (which starts at 10:51) but in addition Luke spent some time explaining the benefits of true flex fuel technology as it is now done in the AEM series 2 and a few other standalones on the market.
I am sure Daniel will be terrorizing the streets of his home town in a car that externally doesnt look too far off from stock.
Aaron
Old Sep 13, 2013 | 04:55 AM
Migsubishi's Avatar
Wow, Awesome, another one!
You guys are doing work over there, keep it up!
Old Sep 13, 2013 | 05:19 AM
06MREvo's Avatar
Almost 500whp @ 19 psi...lol!!! Nice job guys!
Old Sep 13, 2013 | 05:47 AM
miragevo's Avatar
Veteran: Navy
Thumbs up
Outstanding job. I'm very impressed!!!
Old Sep 13, 2013 | 05:52 AM
miragevo's Avatar
Veteran: Navy
JB, can you tell me the pros and cons of using S3's vs. R2's in this particular build? Would the R2's develop more torque down low and you veered toward the S3's to shift the torque to the right to save the drivetrain?
Old Sep 13, 2013 | 08:29 AM
R2s are all about peak power as you rightly guessed. They focus sub 9000 and normally will make peak power high 7s in most bigger applications if there is enough turbo. Since this is a higher revving motor than the LR2.4s we do and the turbo has proven itself in other applications to make peak power pretty high we went with the S3s for the power up top. Drivetrain wasnt a consideration really.
BJ we have done more at 19psi on some builds, almost all of them are large motors though.
Old Sep 13, 2013 | 08:40 AM
LGshow19's Avatar
Great work like always ER!
I really enjoyed the video. Nice to see AEM making some changes to keep up with other ecu options.
Old Sep 13, 2013 | 09:32 AM
miragevo's Avatar
Veteran: Navy
JB, what do recommend max rpm of the SLR engine? Whether you use stock bore or larger the SLR still ends up a 2.2L. Sounds like you have found the best of both worlds. Any chance of getting the factory computer to work with GM flex fuel sensor or equivalent for auto sensing grade of fuel?
Old Sep 13, 2013 | 11:51 AM
420a-t's Avatar
Awesome setup. Ive been looking at this combo on your website (94mm and 153mm). Have you hadany problems with the wristpin being in the oil control ring? Is it better to go with 153mm rids vs standard length rods and different pistons? That combo you have on your website looks very tempting!
Old Sep 13, 2013 | 12:31 PM
I have seen that patch but havent played with it. For a 750+whp car the stock computer really isnt the answer so much. Standalone has many benefits at this level, most notably datalogging speed.
It's the same compression height as a 2.3L motor so the wristpin has been fine.
Old Sep 13, 2013 | 01:34 PM
GotWheelHop's Avatar
Fantastic results Aaron. Looking forward to mine.
Old Sep 13, 2013 | 02:00 PM
boostedwrx's Avatar
800 wheel is the new standard @ ER I guess My car is slow now Good job guys, I bet Dan is having fun with it.
Old Sep 13, 2013 | 02:21 PM
I wouldnt say its a standard, just the result of a dedicated goal
Old Sep 13, 2013 | 04:52 PM
Migsubishi's Avatar
So if looking for 850+ with revs to 8500rpm would you say the s3's would be the way to go then? Or would you still suggest the R2's?
Old Sep 13, 2013 | 09:05 PM
nismo3183's Avatar
i have the same exact motor and turbo coming from ER too! Wish it would come soon, it's been a while
