Evo problems
Old Jun 4, 2013 | 04:17 PM
EvoSeanzie's Avatar
Evo problems
Took about a 2 hour drive the other day, and when I got home I noticed and extra loud ticking noise. Louder than normal.
Today I'm driving, and coming off a turn in like 3rd gear, my car starts supttering like crazy. Not sure what's going on. This is in low RPMs like 2nd-4th. Kinda worried.
Old Jun 4, 2013 | 04:23 PM
ProPilot04's Avatar
I would start by doing a boost leak test, and a compression check. Since you mention a ticking... I would probably do that before driving it again.
Old Jun 4, 2013 | 04:52 PM
EvoSeanzie's Avatar
Its kinda funny, but almost sounds like a subaru.
Old Jun 4, 2013 | 04:54 PM
ProPilot04's Avatar
Thats what I said about my Evo 5 right before thine piston removed itself from thine motor.
Old Jun 4, 2013 | 07:33 PM
EvoSeanzie's Avatar
Oh ****. I hope not. My buddy pulled coil packs from a motor he had laying out and it drastically reduced the ticking and no more Subaru sound
Old Jun 4, 2013 | 09:13 PM
turbotalawd's Avatar
Sounds like a misfire. Check sparkplugs, plug wires, and make sure to double check the injector seals. If there is a leak there, it will make it sound like a subaru.
Old Jun 5, 2013 | 11:32 AM
ProPilot04's Avatar
Yeah... misfire. Weird. I'd still check compression. Find out what caused the problem as well...
Old Jun 5, 2013 | 12:15 PM
donzilla2004's Avatar
Yea, I was chasing a ticking noise forever on my evo 8, ended up actually being a rod knock that presented itself on the highway while coming home, ate up rod bearing on cylinder 2. Lucky nothing blew out of the block. It all started as a loss in power too...
Old Jun 6, 2013 | 08:04 PM
EvoSeanzie's Avatar
JEE-SUS!
Old Jun 7, 2013 | 05:42 AM
JEE-SUS!
That's not good... Did you find the rest of it?
Old Jun 7, 2013 | 06:00 AM
meckert's Avatar
Was going to say you need to check the condition of the plug-- with the electrode missing you likely have a detonation problem at the very least and could be a AF issue. GL in fixing it.
Old Jun 7, 2013 | 06:50 AM
EvoSeanzie's Avatar
Did not. Used a scope. Its not there.
Old Jun 7, 2013 | 08:23 AM
ProPilot04's Avatar
If it was lucky enough to be expelled through the exhaust, I'd check the exhaust side of the turbo just to be sure you don't have any FOD issues.
Old Jun 7, 2013 | 08:52 AM
EvoSeanzie's Avatar
Also. That one plug was not tight at all. Im quite sure they were all tight when the head gasket was changed.
What is FOD?
Old Jun 7, 2013 | 08:56 AM
njboy's Avatar
FOD is a term from the aircraft industry;
Foreign Object Damage
